Fog light is not working - Hyundai Forums : Hyundai Forum
Old 03-01-2012, 08:56 PM   #1 (permalink)
Gary0100
Default Fog light is not working
My fog light is not on anymore... Sad
Gary0100 is offline   Reply With Quote
Old 03-01-2012, 09:53 PM   #2 (permalink)
CHiSEEN's Avatar
Drives 2012 Hyundai Sonata Limited 2.0T
CHiSEEN is an unknown quantity at this point
Need more details than that to suggest anything.
Did you check the bulbs? Wiring harnesses? Any mods?
If all else fails take it to the dealer.
Harbor Gray
2012 Hyundai Sonata 2.0T Limited
XS 6000K HID Low Beams | PIAA 2500K Plasma Ion Yellow Fog Lights | SR LED DRL | MOBIS Tail Lights | VLED 5000K Reverse Lights | PLED 8000K LED Interior Lighting | LED Cupholder Mod | SR Black Fog Light Molding | MOBIS Chrome Lower Door Molding | SR Rear Diffuser - Type 2 | 35% Tint All Around
CHiSEEN is online now   Reply With Quote
Old 03-01-2012, 09:58 PM   #3 (permalink)
Gary0100
Becease my headlight n fog light are hid and they is the problem if I take it back to dealer
Old 03-01-2012, 10:35 PM   #4 (permalink)
sienna1's Avatar
2011 Sonata 2.4L Limited 2012 Veracruz GL FWD
Did you use a relay-harness? If not, you may have released the magic smoke from your junction box ($700 worth).
sienna1 is offline   Reply With Quote
Old 03-01-2012, 11:00 PM   #5 (permalink)
Gary0100
I used relay it was fine for one year but start from 2 days ago my fog light is on sometimes n don't working sometimes
Old 03-01-2012, 11:05 PM   #6 (permalink)
jasen1's Avatar
jasen1 is an unknown quantity at this point
most likely you have a bad ballast that sometime fires and sometimes doesn't. Turn them off.. count to 5 and turn them back on. That should do it. If not, cycle them again.
jasen1 is offline   Reply With Quote
Old 03-01-2012, 11:06 PM   #7 (permalink)
jasen1's Avatar
that typically shows up as a signal light on the passenger side that will not turn off even after the car is shut off. Nor will it activate It stays on bright all the time.
Old 03-01-2012, 11:13 PM   #8 (permalink)
Gary0100
cycle them again?
Old 03-04-2012, 12:24 AM   #9 (permalink)
CHiSEEN's Avatar
you might also want to check the fuse on the relay harness to see if it didn't just blow, that would be easily replaceable. You can tell by putting it through an ohmmeter or just replacing it with a new fuse if you don't have an ohmmeter. I think it should be like a 20 amp fuse, your local auto shop should sell them pretty cheap. I doubt it would be a ballast issue if both of them failed at the same time unless something affected both ballasts to make them both malfunction.
Going to the dealer for this problem is defiantly a no go since the headlights are modded.
Harbor Gray
Old 03-04-2012, 11:00 AM   #10 (permalink)
jasen1's Avatar
cycle them again?
Turn them off then on. You checked all your connections and made sure all the wires are still connected first right?
