GDI Carbon Buildup - Hyundai Forums : Hyundai Forum
Old 11-19-2011, 09:43 PM   #1 (permalink)
Sonata_Guy's Avatar
Drives 2008 Sonata NF Limited
Sonata_Guy
Default GDI Carbon Buildup
Does anyone know what Hyundai has done in relation to carbon buildup in GDI engines?
Direct Injection Fouls Some Early Adopters - AutoObserver
Sonata_Guy is offline   Reply With Quote Quick reply to this message
Old 11-19-2011, 10:12 PM   #2 (permalink)
thebeet is an unknown quantity at this point
Here some good info from BG in regards to GDI . I have used there BG 44k and BG MOA.
BGFuelTest.com 55,742 miles
thebeet is offline   Reply With Quote Quick reply to this message
Old 11-20-2011, 02:03 AM   #3 (permalink)
DWPTECH's Avatar
Drives 2011 Sonata Limited 2.0T, 2005 Chrysler 300C Hemi, 2002 Ford F250 7.3L Diesel.
DWPTECH is an unknown quantity at this point
Thats a very good question! Does Hyundai have a problem in the first place? Are these engines too new to know? I can tell you that when I wipe the exhaust tip when Im detailing the car there is a lot of black in there. When I do the same thing to my Chrysler 300C Hemi, its very clean at the exhaust tips. So, what does it look like in our combustion chambers?
I suppose that the Techron will not help? Or will it? Maybe GDI is a whole new monster. Our driving is mostly highway so that may help a little if in fact we are going to have a problem with this. Did the Hyundai engineers incorporate the injector timing that Ford and Cadillac did to reduce the effects of carbon build up? Also what about our crankcase ventilation system? Is our EGR clean or dirty? Dont know.
No one ever learned anything by doing it right the first time!
DWPTECH is offline   Reply With Quote Quick reply to this message
Old 11-20-2011, 02:37 AM   #4 (permalink)
jdugan4859's Avatar
jdugan4859 is an unknown quantity at this point
I think I remember reading something about them putting a dome in the top of the piston, and it was suppose to fix the carbon problem.
jdugan4859 is offline   Reply With Quote Quick reply to this message
Old 11-20-2011, 08:47 AM   #5 (permalink)
Sonata_Guy's Avatar
Sonata_Guy
That appears to be some pretty good products. I wonder how much they sell for.
At this point I do not know what if anything Hyundai has done to incorporate that ultra precise injector timing that Ford and Cadillac use.
It looks like vehicles in the very near future will operate very precisely by electronic control modules using logic chips. Warranties now become extremely important to cover expensive repairs to all these electronic systems.
I think the piston heads have a donut shaped cavity in them on the GDI engines. The dome (I think) would defeat the purpose of the cavity.
Old 11-21-2011, 01:40 PM   #6 (permalink)
prenedo's Avatar
prenedo
Seafoam will help with buildup.
2012 White Sonata 2.0T
(traded in) 2007 Mazdaspeed 3
prenedo is offline   Reply With Quote Quick reply to this message
Old 11-22-2011, 08:03 AM   #7 (permalink)
leesrt's Avatar
Drives 2013 Genesis Coupe 3.8 Track and 2013 Elantra GT
leesrt is an unknown quantity at this point
The black soot on your exhaust tips are from the car being turbocharged. All turbo cars do it, GDI or not. It's from the fuel mix being richer to mix with the higher flow of air in the intake manifold. When you come off throttle the pressurized air stops and the fuel mix is rich until the ECU catches up. Rich fuel mix burns black.
Its best to wait and see if this will be a problem but I can attest that the BG fuel line cleaner certain dealerships do is excellent.
Mods: K&N air filter and BOV filter, 21% tint, T-bolt clamps, debadged and rebadged with KDM, 6k XS HID and LED, Lamin-X tinted Tails & Fogs
leesrt is offline   Reply With Quote Quick reply to this message
Old 11-22-2011, 09:37 AM   #8 (permalink)
veilside1's Avatar
2011 Sonata GLS, 2012 SantaFe GLS
veilside1 is an unknown quantity at this point
That thing got a Hemi??? Yes, our Sonata's do have Hemispherical combustion chambers
As far a carbon buildup, only time will tell... The Theta II is too new of a platform for us to know. But i'm sure Hyundai has addressed this in some novel way, as they have not been known to follow to pack in any of their innovations. Seafoam may help when sucked into the PCV system, but we'd need some before/after pics to quantify the results and then combine them with a suitable interval.
For now i am content to let Hyundai worry about it with the 100k powertrain warranty...
Wise men still seek Him!
veilside1 is offline   Reply With Quote Quick reply to this message
Old 12-08-2011, 02:56 PM   #9 (permalink)
swatpup102
Don't want carbon build up to occur? Drive it hard, not one single sporty car I've ever owned has had carbon build up, I think most of it is due to not "blowing it out" sometimes by regular drivers. Constantly keeping the engine at basically above idle rpm's all the time in commuting doesn't allow the carbon to burn off under higher pressure and temps of the engine running hard.
Don't blow it up or anything, just put it through some paces every now and then.
swatpup102 is offline   Reply With Quote Quick reply to this message
Old 12-08-2011, 03:47 PM   #10 (permalink)
jasen1's Avatar
jasen1 is an unknown quantity at this point
/\ that probably used to work with non-direct injection engines. Those inject the fuel into the cylinder before the intake valves essentially rinse the valves every time gas comes into the cylinder.
With direct injection, the fuel is injected directly into the combustion chamber and bypassing the valves on the way in. That's where people are seeing the build up. Driving it hard won't make a difference because of the way the motors are built.
Me, I will start putting in bg product shortly. I found a local dealer who will sell it over the counter and iirc it's around 50 bucks for the moa and 44k.
jasen1 is offline   Reply With Quote Quick reply to this message
