N (neutral) is your friend - Hyundai Forums : Hyundai Forum
Old 07-05-2012, 03:55 PM   #1 (permalink)
Fishnrib's Avatar
Retired USN & Civ Svc IT for USN 2011 Sonata Hybrid Premium DOB 2/14/11 (wife's car) 2003 Santa Fe
Fishnrib is an unknown quantity at this point
Default N (neutral) is your friend
I was trying N when going down hills but since my drive with Wayne I found that you could coast for a very long way on the flat as well. Driving my Santa Fe and using the AT like a stick w/o a clutch I coast going the speed limit over half the time now. I also try and not to get the rpm's over 2,000. My first fill-up using this method netted me 19.5 mpg instead of my normal 15-16 mpg.
Tom
Wayne and Tom
Fishnrib is offline   Reply With Quote
Old 07-05-2012, 04:07 PM   #2 (permalink)
snead_c's Avatar
Drives Sonata Hybrid Wife Drives Prius
snead_c
Does coasting in N negate regeneration in hybrid ?
snead_c is offline   Reply With Quote
Old 07-05-2012, 04:19 PM   #3 (permalink)
Fishnrib's Avatar
Yes, only use N for coasting when you have a good charge on the battery 60-80%. That way you can use the battery later when you need it. You can only charge the battery while in D (drive).
Tom
Wayne and Tom
Old 07-05-2012, 11:36 PM   #4 (permalink)
rbbayernde's Avatar
Drives a 2011 Sonata Hybrid (base model) Silver
rbbayernde
So far I've never used "N" and still get over 40 mpg.
rbbayernde is offline   Reply With Quote
Old 07-06-2012, 10:20 AM   #5 (permalink)
Sonata Hybrid
glerkel
Send a message via Yahoo to glerkel
In most vehicles with A/T, towing with the driving wheels on the ground is bad news for the transmission. I am wondering if coasting in neutral when the engine may be off is the same as a towing situation.
glerkel is offline   Reply With Quote
Old 07-06-2012, 10:54 AM   #6 (permalink)
swduncan's Avatar
2012 5dr accent se, 6 spd. M/T, 2011 dr 650 Suzuki 1976 BMW R75/6
swduncan is an unknown quantity at this point
That's what I was wondering too. The trans MAY not get proper lubrication while coasting at highway speeds in neutral. Best check with Hyundai.
swduncan is offline   Reply With Quote
Old 07-06-2012, 10:55 AM   #7 (permalink)
2002 Sonata LX V6
Chloe2002
i would think constantly shifting between N and D would put unnecessary wear on the transmission. then again i'm the guy who comes to a complete stop, full brake down, shift, wait for the connection, then ease off onto the gas lol
Chloe2002 is offline   Reply With Quote
Old 07-06-2012, 11:59 AM   #8 (permalink)
MarkJnK's Avatar
Sonata Hybrid Prem. 25,000+kms Mar 18 Build date. No CEL/NVLD issues yet... Amazing Car!
MarkJnK
I've been quite amazed at the ease of coasting in the HSH, it carries speed effortlessly. You can see they put alot of effort into reducing any drag aerodynamically and in the driveline. But I figured that coasting and not regenerating the battery pretty much cancelled out any benefit of coasting. Interesting, will have to try it again.
Mark from Ontario
MarkJnK is offline   Reply With Quote
Old 07-06-2012, 12:30 PM   #9 (permalink)
Fishnrib's Avatar
Don't coast in N unless your battery is over 60% and as for wearing out the transmission Wayne shifts 1,000's of times on his cross country trips with AT without any problems.
Tom
Wayne and Tom
Old 07-06-2012, 12:40 PM   #10 (permalink)
Drives HSH Sonata Hybrid
dun4cheap is an unknown quantity at this point
The other problem with using neutral is that it turns off cruise.
dun4cheap is offline   Reply With Quote
