Question about transmission fluid. - Hyundai Forums : Hyundai Forum
Old 12-15-2013, 02:24 PM   #1 (permalink)
Hyundai 2013 YF Sonata Limited
DewZ013 is an unknown quantity at this point
Default Question about transmission fluid.
Does it work as the same as engine oil? how do you maintain it? do you change it every 5000 miles? My car just hit 10k miles, and I have never done anything with transmission fluid. I heard from somewhere saying that you have to flush at certain miles or years of ownership. thanks guys
DewZ013 is offline   Reply With Quote Quick reply to this message
Old 12-15-2013, 02:32 PM   #2 (permalink)
2011 Sonata SE
shockergeek
I think the dealership says to drain and fill every 30,000 miles. I had a flush and fill done at 100,000 miles. You wont want to do it every 5,000 miles...the tranny fluid is like $18 a quart
shockergeek is offline   Reply With Quote Quick reply to this message
Old 12-15-2013, 02:59 PM   #3 (permalink)
Drives 2011 Sonata Limited Drives 2004 XG350L
Bobb4484 is an unknown quantity at this point
The Hyundai Sonata auto transmission is now considered a sealed system. There is a check point but no dip stick for fluid level inspection. I would suggest reading the owners manual under service recommendation for the drain and fill timing. I believe its safe to say don't touch it until at least 60,000 miles. Flushing of the system is a dealer inspired refill method and I do not believe its endorsed by Hyundai.
The dealers will tell you anything, like 30,000 miles, where the real requirement may be 60,000, 100,000 or maybe never. I've not priced the transmission service charge by a dealer for the Sonata but would guess its around $150-200 or more. On my 2004 XG350, the dealer got me for $130 at 30,000 miles when the manual called for drain and fill at 105,000 miles. It doesn't hurt to change early, but why do so, when its not needed.
There is a lot on information on the forum regarding when to change, how to do it and etc. Do a search.
Bobb4484 is offline   Reply With Quote Quick reply to this message
Old 12-15-2013, 03:45 PM   #4 (permalink)
armtdm's Avatar
Drives 13 Elantra GLS Pref Package Drives 12 Lincoln MKZ Hybrid
armtdm is an unknown quantity at this point
I believe that there is an owner's manual in the glove compartment that will answer all of these questions. You may wish to read it! You seems to have several mods on the car but are asking about tranny fluid maintenance, something wrong with the picture.
armtdm is offline   Reply With Quote Quick reply to this message
Old 12-15-2013, 04:43 PM   #5 (permalink)
Mikemu's Avatar
2013 Sonata replaced by: 2014 Azera Limited with Premium - Porcelain White w/Black interior
Mikemu is an unknown quantity at this point
Really no such thing as "lifetime" fluid but if you don't plan to keep the car beyond 100k miles, I wouldn't worry about changing the trans fluid anytime soon.
Mikemu is offline   Reply With Quote Quick reply to this message
Old 12-15-2013, 05:47 PM   #6 (permalink)
2010 Sonata GLS 2012 Sonata GLS 2013 Sonata GLS
rafciu123
I paid hyudai dealership ~$170 for drain and fill on my 2012 Sonata, it was so expensive because 5 quarts of Hyundai ATF cost $100. Drain and fill for NF cost me ~$90 (cheaper ATF). I have the fluid changed every 2 years or 30K miles, whichever comes first.
rafciu123 is offline   Reply With Quote Quick reply to this message
Old 12-15-2013, 07:09 PM   #7 (permalink)
destro is an unknown quantity at this point
No he doesn't read the manual, nor any prior posts on here. He just makes twenty threads on the simple things he can't understand. Will likely not ever reply any further to the thread.
destro is offline   Reply With Quote Quick reply to this message
Old 12-15-2013, 07:16 PM   #8 (permalink)
Smoke1991's Avatar
11 Sonata 2.4
Smoke1991 is an unknown quantity at this point
a drain and fill on a YF takes like 2 or 3 quarts... FYI
2011 Sonata Limited Silver/Black leather with Nav.
To many mods to list...
(I don't know what I am talking about, so listen to the other guy.... he knows better)
Smoke1991 is offline   Reply With Quote Quick reply to this message
Old 12-15-2013, 07:30 PM   #9 (permalink)
Mikemu's Avatar
So plenty old fluid remains?
Old 12-15-2013, 07:32 PM   #10 (permalink)
Smoke1991's Avatar
11 Sonata 2.4
you said drain and fill, drain and fill is like 2-3 quarts. full exchange using a machine you want to use 12 to 16 quarts.
