Keys locked in trunk! PLEASE HELP! I'm stranded!!! - Hyundai Forums : Hyundai Forum
Old 06-23-2013, 04:14 PM   #1 (permalink)
2013 Hyundai sonata
Rlmccabe91 is an unknown quantity at this point
Default Keys locked in trunk! PLEASE HELP! I'm stranded!!!
Ok here's my story.
2013 Hyundai sonata
I wrecked my 2006 Subaru Sti so I got this as a rental.
I carelessly put something in the trunk and sent the keys with it, no big deal right? So I make a call and have someone come unlock the driver side door for $30, alarm goes off and I hit the trunk button......no luck? I keep hitting it and no luck?
So I pop the hood and disconnect the battery thinking it would reset the alarm but it didn't do any good.
It's impossible to go thru the back seat.
Please help!!!!!
Rlmccabe91 is offline   Reply With Quote Quick reply to this message
Old 06-23-2013, 04:30 PM   #2 (permalink)
tmmyers's Avatar
2011 Sonata GLS -Radiant Silver
tmmyers is an unknown quantity at this point
Yeah sounds like your stuck in a pickle! I do wish there was a to gain access to the truck threw the back seats, like maybe the access hole in the arm rest like some other models have it... Only opinion I could think of is have someone get your spare keys.
2011 Sonata GLS 2.4
-Radiant Silver
-18% window tint
-18" Motegi mr118 rims
- Plasti-dipped grill and rear trunk chrome piece
- Debadged rear sonata logo.
-Rebadged front & rear with Luxury Generation Emblems
- Installed a Pioneer AVH-x1500DVD player
- WeatherTech in-channel dark smoke rain guards
- K&N 69 Series High Performance Typhoon Air Intake
Follow me on Instagram @ DoctorDeath1229
tmmyers is offline   Reply With Quote Quick reply to this message
Old 06-23-2013, 04:55 PM   #3 (permalink)
orrider's Avatar
2006 Sonata
orrider is an unknown quantity at this point
One more item I don't like about the current generation of Sonatas. With the previous version one had to deliberately lock both seat backs and the trunk to secure access where only the electronic key would open the trunk. But I guess that cost too much.
orrider is offline   Reply With Quote Quick reply to this message
Old 06-23-2013, 04:58 PM   #4 (permalink)
Drives Sonata 11 YF SE SW
Txboy11SE is an unknown quantity at this point
Cant lock the key fob in the trunk with a pushbutton start... lol
Txboy11SE is offline   Reply With Quote Quick reply to this message
Old 06-23-2013, 05:00 PM   #5 (permalink)
jimrinflorida's Avatar
2013 Genesis Cp 3.8 GT 2011 Sonata Ltd 2.0 Navi 2011 Elantra Ltd Navi 2006 Sonata GL
jimrinflorida is an unknown quantity at this point
Checked mine. The only way I see is to jump battery power to the trunk release solenoid at the latch thru the wiring harness somewhere under the door sill plates and carpeting?
jimrinflorida is offline   Reply With Quote Quick reply to this message
Old 06-23-2013, 05:04 PM   #6 (permalink)
tmmyers's Avatar
Originally Posted by jimrinflorida View Post
Get a coat hanger or something and pull the emergency trunk release handle inside the trunk thru the rear armrest hole passthru? Checking mine now to see if it's possible.
Good luck, that seems nearly impossible
2011 Sonata GLS 2.4
-Radiant Silver
-18% window tint
Old 06-23-2013, 05:11 PM   #7 (permalink)
13SonataScott's Avatar
Call the rental company. This happens more than you know.
13SonataScott is offline   Reply With Quote Quick reply to this message
Old 06-23-2013, 05:12 PM   #8 (permalink)
That's why I quickly edited after I checked mine. I'm looking at the wiring schematics now on Hyundai service website. I see a trunk release relay in IP junction block. Figuring out a fix now.
Old 06-23-2013, 05:18 PM   #9 (permalink)
There is a red wire that runs from the IP junction block trunk release relay to the trunk release motor. Find the relay in the IP junction block then the red wire and jump battery power to it. The trunk will release. That's how I would do it if I had all day. Or call the rental company as mentioned above. They have a spare set of keys.
Old 06-23-2013, 05:46 PM   #10 (permalink)
Damifino329's Avatar
2013 Sonata Limited 2.4L 2011 Santa Fe GLS 2.4L 2001 Santa Fe GLS 2.7L
Damifino329 is an unknown quantity at this point
I have a 2013 Sonata (LTD proximity key). I also unsuccessfully just explored trying to gain entry through the cabin. Both split rear seats are latched at the top. They're both just slightly toward the car's center. The release is unfortunately in the trunk. Nothing at all inside the car. Nor entry through the center armrest. No entry through the gas door either. A very big MAYBE running a long screwdriver down from the top of the seat to unlatch. Frankly I'd go with Jimrinflorida's idea.
Damifino329 is offline   Reply With Quote Quick reply to this message
