Rear brake install problem HELP! - Hyundai Forums : Hyundai Forum
Old 05-16-2013, 10:11 PM   #1 (permalink)
2011 Sonata Turbo
Evan91 is an unknown quantity at this point
Default Rear brake install problem HELP!
Hello I am doing rear brakes on my 11 sonata and to replace the rotors I had to remove the "rear upper arm" I cannot get the the bolt hole to line up spent many hours at this and nothing works.
Evan91 is offline   Reply With Quote Quick reply to this message
Old 05-16-2013, 11:09 PM   #2 (permalink)
robspeedGLS's Avatar
robspeedGLS is an unknown quantity at this point
can you take a pic of the problem?
robspeedGLS is offline   Reply With Quote Quick reply to this message
Old 05-16-2013, 11:14 PM   #3 (permalink)
Smoke1991's Avatar
11 Sonata 2.4
Smoke1991 is an unknown quantity at this point
rear rotors are a bitch... remove the lower bolt for the shock, swing it inwards towards the center of the car, then remove the control arm bolt. then you can get to the upper saddle bolt.
2011 Sonata Limited Silver/Black leather with Nav.
To many mods to list...
(I don't know what I am talking about, so listen to the other guy.... he knows better)
Smoke1991 is offline   Reply With Quote Quick reply to this message
Old 05-17-2013, 02:45 PM   #4 (permalink)
Drives 2011 Hyundai Sonata
hawktomania is an unknown quantity at this point
I've replaced the rear caliper before because it was stuck. I blame on Hyundai engineer for placing the rear upper arm and shock absorber at a such inconvenient location. What I did to line up the bolt hole was that I placed a jack under the rear rotor and then adjust the height of the jack until two holes get lines up.
hawktomania is offline   Reply With Quote Quick reply to this message
Old 05-17-2013, 02:52 PM   #5 (permalink)
sienna1's Avatar
2011 Sonata 2.4L Limited 2012 Veracruz GL FWD
Also had a tough time re-installing that bolt. I use an open-end wrench on the control-arm to help align the hole, it allows you to twist the control arm in the vertical plain while inserting the bolt.
sienna1 is offline   Reply With Quote Quick reply to this message
Old 05-17-2013, 08:51 PM   #6 (permalink)
hoby2hq2's Avatar
2011 Sonata 2.0T Limited
hoby2hq2 is an unknown quantity at this point
I don't like the sounds of this...coming from a NF this sounds much more involved. The NF was a simple off/on for all rotors.
Old Garage: 2009 Sonata 2.4; 1999 Grand Cherokee 4.0; 1999 300m 3.5; 1994 Firebird 3.4; 1995 Beretta 2.2; 1989 Grand AM 2.5
hoby2hq2 is offline   Reply With Quote Quick reply to this message
Old 05-17-2013, 09:35 PM   #7 (permalink)
guitarfish's Avatar
'12 Sonata GLS
guitarfish is an unknown quantity at this point
Why do they design s--t like this? Jeez.
guitarfish is offline   Reply With Quote Quick reply to this message
Old 05-19-2013, 10:14 AM   #8 (permalink)
hoby2hq2's Avatar
Anyone else doing this feel up to a photo DIY for rear rotors?
Old 05-19-2013, 10:09 PM   #9 (permalink)
2011 Sonata Turbo
Thanks for the help all. What i did was take a die grinder to the arm so it would fit better than put vice grips on the arm to twist it to the correct angle than tap the bolt in with a hammer. This is a very dumb design to say the least.
Old 05-20-2013, 06:34 PM   #10 (permalink)
redum1's Avatar
Drives 2012 sonata 2.4
redum1 is on a distinguished road
I replaced my rotors and brakes took 2 hours 12 minutes
redum1 is offline   Reply With Quote Quick reply to this message
