2013 Sonata SE 2.4L with 1700 Miles - Questions - Hyundai Forums : Hyundai Forum
Old 01-18-2013, 06:39 PM   #1 (permalink)
2013 Sonata SE 2012 Honda Odyssey
someone_someone is an unknown quantity at this point
Default 2013 Sonata SE 2.4L with 1700 Miles - Questions
Hi All
I have purchased it 1 month back (my second sonata after my 2006 Sonata V6)
i have 1700 miles on it currently and i drive on freeways 95% of the time.
wanted to know if i can change it to Synthetic now. Mobile 1 (5-20) ?
someone_someone is offline   Reply With Quote
Old 01-18-2013, 07:04 PM   #2 (permalink)
Drives: 2013 Sonata GLS, 2009 Venza AWD V6, 2010 Toyota Corolla, 2008 Pontiac G5, 2010 Mazda 3 G
Danno is an unknown quantity at this point
Sure you can but I frankly would wait to at least 3,750 miles which is the first change under severe service. Some say the rings set in better if you leave the orginal oil in vs. changing it out early. If you could put your location in your profile, it would help understand your operating environment. If you are in a cold climate, an early change to synthetic would be good. I changed mine to Pennzoil Platinum 5W20 at 3,750 miles. -20F here tonight. Use a Hyundai filter in any case.
Danno is offline   Reply With Quote
Old 01-18-2013, 07:09 PM   #3 (permalink)
2012 Sonata SE - XS 6k HIDs (Lows & Fogs), Homelink Auto-Dim Compass Mirror, De/Re-Badged.
Wireless Guy is an unknown quantity at this point
Yep, you can no problem. I run Pennzoil Platinum 5W-20 (full synthetic) with an OEM Hyundai filter.
2012 SE 2.4 Pacific Blue Pearl
De/re-badged (F24GDI)
XS 6000k HIDs Lows & Fogs (w/relay harnesses)
35% Tint all around
Homelink/Compass Mirror
Cup Holder LED Mod
LED Interior Conversion (6000k)
Wireless Guy is offline   Reply With Quote
Old 01-18-2013, 07:51 PM   #4 (permalink)
Hi
Thanks for the input. im in sunny San Diego, CA
Old 01-18-2013, 07:55 PM   #5 (permalink)
another question is whether this is a good choice to replace the day time driving light?
i have seeing the yellowish running lamps on a cool car.
2PC H8/H11 High Power 6500K Xenon White 7.5W SMD LED Head Fog Driving Light Bulb
2pc H8 H11 High Power 6500K Xenon White 7 5W SMD LED Head Fog Driving Light Bulb | eBay
Old 01-18-2013, 08:10 PM   #6 (permalink)
11SonataScott's Avatar
2013 YF 2.0T Premium & Optima SE V6
11SonataScott is an unknown quantity at this point
^ agreed. I'm running the same thing in my '11 2.4 with almost 60,000 miles on it. I run 5W-30 in the warmer months. To the OP; Being in San diego you might consider it too, it's rarely cold there, and often pretty warm to hot.
11SonataScott is offline   Reply With Quote
Old 01-18-2013, 08:31 PM   #7 (permalink)
Kandionkhrome1's Avatar
2011 Sonata GLS Phantom
Kandionkhrome1 is an unknown quantity at this point
I'm in Texas and I use 5w-30 Mobil 1 full synthetic.
Sent from my iPhone using AutoGuide.com Free App
See garage for list of mods.
Kandionkhrome1 is online now   Reply With Quote
Old 01-21-2013, 12:11 PM   #8 (permalink)
MODERATOR
jglopic's Avatar
Drives YF Sonata Hybrid
jglopic is an unknown quantity at this point
I have considered this myself. I am a little cautious to do it, as LED bulbs typically will not be as bright as a halogen bulb. This is fine for fog lights, but for the DRL's (which are also the high-beams), you lose the option for a real high-beam function.
Also, be careful of LED bulbs on eBay. I bought some for my fogs which don't fit. Turns out the circuitry was a little too big. It may not be an issue for the bulbs you are looking at (as they are a different style bulb than I purchased), but at least check the return policy to make sure a non-fitting bulb won't end up being your problem, not theirs.
Touring the greater Houston area and trying to save a little gas doing it!
jglopic is offline   Reply With Quote
Old 01-21-2013, 05:24 PM   #9 (permalink)
Thanks - i should have it in my hand in 2 or 3 days. will try it out and update here on the results.
