Shark racing drl LEDs problem! - Hyundai Forums : Hyundai Forum
Old 11-17-2012, 01:58 PM   #1 (permalink)
xgiannix's Avatar
2011 Sonata SE
xgiannix
Default Shark racing drl LEDs problem!
Ok so I bought my DRLs from shark racing a year ago, my driver side LEDs went out and I had to send then back. After 3 months I got them back but now the driver side doesn't go on, only when I turn my lights completely on. The passenger side I have no problem with. Anyone else have this issue? The lights work they just don't go on. Very frustrated I'm not waiting another 3 months to have this fixed...
Too much to list -------> My Garage
xgiannix is offline   Reply With Quote
Old 11-17-2012, 03:16 PM   #2 (permalink)
2011 Sonata GLS MT
Fox Mulder is an unknown quantity at this point
If they do go on properly when you turn your lights on, that means the LED strip itself is ok and there is an issue with the harness. You can verify this by swapping the harnesses left-to-right.
If it is in fact the harness, it should be a simple repair for someone with basic electronic skills and soldering equipment.
Fox Mulder is offline   Reply With Quote
Old 11-18-2012, 12:50 PM   #3 (permalink)
PokerMunkee's Avatar
2012 Sonata Limited 2.0T
PokerMunkee is an unknown quantity at this point
Are these DRL LEDs that cheap? It seems about everyone has issues after a year or so. I really want them but don't want to regret dropping $200 to have them fail in 12 months.
2012 Radiant Silver Sonata Limited 2.0T
Built 8/31/11
Mods: Spoiler, Mud Guards, Clear Bra, V1 Hardwire
27% Tint, XS 6000K HIDs, PrecisionLED 6000K everywhere
PokerMunkee is offline   Reply With Quote
Old 11-19-2012, 11:12 AM   #4 (permalink)
Drives Sonata 2.0T SE
Lordvex
Lol, add me to that list. A few months back they both started condensating inside. Well, the driver's side got so bad that water actually collected up past the first LED on the lower part and the LED doesn't work anymore. The water is making it's way up higher...I have to get them off and dry them out and see what I can do. I never contacted Shark Racing about it yet. OP, you said after a year they still replaced it/fixed it for you?
Lordvex is offline   Reply With Quote
Old 11-19-2012, 12:58 PM   #5 (permalink)
xgiannix's Avatar
2011 Sonata SE
xgiannix
Yeah, they replaced it no problem. It appears that its not the actual LED light thats the problem but the harness. I have already cut the plastic off, and started checking the wires. There doesnt seem to be any loose wires. Does anyone know of a wiring diagram for these harnesses?
Old 11-19-2012, 02:08 PM   #6 (permalink)
Lordvex
I remeber back when they were first selling the lights that they had a newer guy working on them and had some wires switched and they gave us info on how to switch them back inside the harness (no splicing/soldering required). Let me see if I can find it.
EDIT:
I can't seem to dig it up. I thought it was on the thread with them selling it. Sorry.
I have an idea though, take off the other harness and see what's different between the one that works and doesn't. Check the PINOUTS...make sure the same colors match up on both.
Old 11-19-2012, 06:06 PM   #7 (permalink)
doc_aa's Avatar
2011 Sonata GLS Pearl white
doc_aa is on a distinguished road
Change the 40 amp 12volt big relay in the harness. I had one failed after a year. Im assuming you only opened one drl-delete-harness so its the same relay used in HID relay harness just like the one pictured below. The small relay just before the led connectors is the turn-signal/blinking relay.
[IMG]http://www.hyundai-forums.com/222-yf-2011-sonata-i45/
(I dont have time to edit but its the big relay not circled on the opposite left.) You're lucky cuz most sellers would say electronic parts and components doesnt have warranty after a short period of time and SR replaced yours even after a year... LoLz !
6000k Lows and Fogs, Retrofit Blazer Projector fogs, Led Fog DRL strips, Led everything, clear door lens, inner taillight mod, Luxgen badges, HP Black 05 Tint, Leather seatcover, Mobis mudflaps, Rear diffuser, Rearview mirror backup camera, Rear bumper Led reflectors, led footwell lighting, under-mirror led puddle lights, Paddle shifters, UR Strut Bar, Injen SRI.
doc_aa is offline   Reply With Quote
Old 01-05-2013, 06:05 PM   #8 (permalink)
stunt101's Avatar
Drives Sonata YF 2011 GLS
stunt101
Ok, I'm having the issue with the turn signal not working with the Shark Racing DRL lights on one side.
My relay says 40A 14VDC. It does say 12V at the top too. Picture below.
Where did you guys purchase your replacement relays. Would this one from radio shack work? 12VDC/40A SPST Automotive Relay : Automotive Relays | RadioShack.com
The VDC is different between them, would this be an issue?
Thank you!
stunt101 is offline   Reply With Quote
Old 01-05-2013, 06:32 PM   #9 (permalink)
2011 Sonata GLS MT
The one from Radio Shack will work just fine, as will any automotive relay. The 40A rating is overkill for the application although there is no harm in using it. A 20A or 30A relay would be fine as well.
I'd want to make sure the relay is the problem before replacing it. There could be a simple wiring issue (broken connection).
Old 01-05-2013, 10:59 PM   #10 (permalink)
stunt101's Avatar
stunt101
Great, and thank you, will give it a try.
