iPhone 5 and 2011 Hyundai Sonata - Hyundai Forums : Hyundai Forum
Old 09-24-2012, 04:54 PM   #1 (permalink)
Jamiespeck
Default iPhone 5 and 2011 Hyundai Sonata
Like it says has anyone got a iPhone 5 and does the lighting cable hook right into the USB port and work. I have a 2011 SE sonata with NAVI.
Jamiespeck is offline   Reply With Quote Quick reply to this message
Old 09-24-2012, 05:15 PM   #2 (permalink)
2011 Sonata SE
RickSide is an unknown quantity at this point
I too have a 2011 Sonata SE with NAV and I'm curious as well.
I have a sneaking suspicion it won't work with the stock Apple cable as my iPhone 4 won't (needs the Hyundai cable then it works just fine).
I very curious to know if the iphone 5 coupled with the new adapter (that connects the new 8pin lightning connector to the old 30 pin connector) works as well.
Of course, if someone from Hyundai were to offer some insights that would be fantastic (though so far all I've seen from those who have reached out to Hyundai has been a 'wait and see' type reply).
RickSide is offline   Reply With Quote Quick reply to this message
Old 09-24-2012, 05:25 PM   #3 (permalink)
quietfly's Avatar
Drives Sonata YF
quietfly is an unknown quantity at this point
the iphone 5 requires a different cable to begin with so i doubt it would work.
quietfly is offline   Reply With Quote Quick reply to this message
Old 09-24-2012, 05:43 PM   #4 (permalink)
Jamiespeck
what I was asking if the new cable works in that usb port now cause it is a newer connection. Not with the old 30 pin but the new thunderbolt cable.
Old 09-24-2012, 05:44 PM   #5 (permalink)
jglopic's Avatar
Drives YF Sonata Hybrid
jglopic is an unknown quantity at this point
Hyundai is probably just getting to test the new iPhone and cable. Apple is famous for not sharing in advance of changes, and this new cable is no exception. Most accessory manufacturers didn't see it before the press conference where it was revealed.
Touring the greater Houston area and trying to save a little gas doing it!
jglopic is offline   Reply With Quote Quick reply to this message
Old 09-24-2012, 05:47 PM   #6 (permalink)
2011 Sonata SE
The only hope I hold for this is that the 8 to 30 pin adapter has a DAC built in from what I'm told. This means it's at least possible for the DAC to convert back into the correct format for the old 30 pins, thus (reasonable assumption alert) into a format the current hyundai cable supports.
Old 09-24-2012, 06:53 PM   #7 (permalink)
Drives Sonata---not by choice
DVDDave is an unknown quantity at this point
buy an android...
DVDDave is offline   Reply With Quote Quick reply to this message
Old 09-24-2012, 07:08 PM   #8 (permalink)
Drives Sonata Limited 2011
azweig
You just need to buy the adapter that fits on top of the 30 pin
azweig is offline   Reply With Quote Quick reply to this message
Old 09-24-2012, 07:41 PM   #9 (permalink)
Jamiespeck
Originally Posted by DVDDave View Post
buy an android...
Had one I like being able to be Away from the outlet to do things other than having a dead android.
Old 09-24-2012, 07:58 PM   #10 (permalink)
Hyundai Sonata 2012
thepoetvd776 is an unknown quantity at this point
Which android did you have?
Because my Samsung Galaxy S 3 lasts me the whole day.
thepoetvd776 is offline   Reply With Quote Quick reply to this message
