Oil Pan Torque - Page 4 - Hyundai Forums : Hyundai Forum
Old 07-11-2012, 12:46 PM   #31 (permalink)
Mikemu's Avatar
2013 Sonata replaced by: 2014 Azera Limited with Premium - Porcelain White w/Black interior
Mikemu is an unknown quantity at this point
Originally Posted by Bearcats View Post
Don't forget to take the opportunity to pre-fill the oil filter prior to installation. Depending on the filter it will take 1/8th to 1/4 of a quart to fill. Saves on a bit of startup wear and cost nothing!
And dont forget to put a NEW crush washer (or make sure the old one is still on the drain bolt) or you WILL get a weeping leak from the drain bolt. Ask me how I know...
You still need the washer with the new valve?
Mikemu is offline   Reply With Quote Quick reply to this message
Old 07-12-2012, 04:22 PM   #32 (permalink)
guitarfish's Avatar
'12 Sonata GLS
guitarfish is an unknown quantity at this point
Originally Posted by Dave-S View Post
The very first time I changed my oil I installed the Fumoto drain valve to do away with having to deal with the drain plug at each oil change. You might want to get this valve and try it on the old pan first to see if it leaks. It has a regular gasket not one of those crush washers. Fumoto Valve | Qwik Valve™
I bought one of these today, thanks for the tip!
guitarfish is offline   Reply With Quote Quick reply to this message
Old 07-12-2012, 04:35 PM   #33 (permalink)
jdr43's Avatar
Drives 2013 Sonata and 2003 Elantra GT
jdr43 is an unknown quantity at this point
Which one did you purchase ? (model #)
jdr43 is offline   Reply With Quote Quick reply to this message
Old 07-12-2012, 04:45 PM   #34 (permalink)
guitarfish's Avatar
'12 Sonata GLS
F-106
Old 07-13-2012, 10:07 AM   #35 (permalink)
2012 Hyundai Sonata SE 2010 Ford Ranger XLT 2000 Honda Civic Si
Buckeyeman is on a distinguished road
Ok, here's an update. The wife takes her car over to the dealer and says the drain plug is leaking oil so they put it up on the lift and they tell her the drain plug is loose. She brings home the invoice and it says "tightened drain plug to mfg. specifications". I tell her no way was that drain plug loose cause I checked it twice with a wrench not a torque wrench and it was tight and still leaking. So I check it after the dealer torqued it and so far no leak. I guess a word of advice is always use a torque wrench and tighten to 25-32 ft.lbs. I've never in all the years of changing oil used a torque wrench to tighten a drain plug. I told the wife not to cancel the pan that's on order just yet. I'm not convinced that the dealer took care of the problem.
Buckeyeman is offline   Reply With Quote Quick reply to this message
Old 07-13-2012, 10:18 AM   #36 (permalink)
mkong is an unknown quantity at this point
Dealership charge $29 for oil change, why mess with it?
mkong is offline   Reply With Quote Quick reply to this message
Old 07-13-2012, 10:25 AM   #37 (permalink)
guitarfish's Avatar
'12 Sonata GLS
Stealership doesn't use synthetic. Stealership is two hour round trip.
Old 07-13-2012, 11:14 AM   #38 (permalink)
Bearcats's Avatar
'13 Ford Fusion Titanium ¶ ¶ '11 Sonata YF 2.4 Limited (Wifes)
No synthetic. job not performed correctly. Oil all over my wind pan which then leaks on my driveway. Over torqued drain bolts that shake the car. Tons of reasons.
KDM YF LED tails | Llumar 30% Ceramic Tint | V-LED 5K Interior lighting | XenonSupply 4300K Slimline HID's | The "cup" mod
Bearcats is offline   Reply With Quote Quick reply to this message
Old 07-13-2012, 12:45 PM   #39 (permalink)
Drives 04 SAAB 9-5, 02 Dodge Dakota 4x4
rico567
First item, to get it out of the way: what do the bolts holding the oil pan to the bottom of the block have to do with the oil drain bolt? How can a leak in one be related to the other?
Second item: Who can possibly believe that it takes 24-32 foot-pounds of torque to secure a drain bolt? My guess is that it's an aluminum pan, and this is a recipe for disaster (stripping the threads out, sooner or later).
I have done my own oil changes (steel bolt in an aluminum pan, copper washer) on 12 SAABs over 40 years. That's a lot of oil changes, and I have never, ever had a problem.
When putting the drain bolt back in, if Hyundai supplies an aluminum crush washer, throw it as far as possible and go to Auto Zone or somewhere and buy a copper one. Copper has "spring back" when the bolt is tightened, aluminum has none. This means that the washer is reusable, and it helps to maintain the tight fit.
My technique for re-installing the bolt is as follows: 1) screw the bolt back in finger tight, making sure you have that copper washer on there, 2) using a standard 3/8 drive ratchet and a socket of whatever size your bolt is, tighten the bolt just snug, and then give the handle of the ratchet one (1) nice tug. That is all it takes, and it's certainly not more than 10 foot-pounds. If you feel you cannot control this process well enough, install a Fumoto valve in place of the drain bolt (Google is your friend).
I have done oil changes on several of my kids' cars, and the guy at the dealer or Jiffy-Lube must have thought he was reinstalling the head bolt on a D9 Caterpillar. I have had to use breaker bars to get the drain bolt out. I have had several oil filters put on so tight that the housing of the filter was distorted. This should never, ever happen.
(NB: the following may be more information that you need or want)
Torquing fasteners is something that, if done repeatedly at high torque, is going to weaken not only the fastener but the threads it's engaging. Sooner or later, those threads are coming out. With some things, like cylinder heads, it's unavoidable. With things like oil pan drain bolts, it most certainly is.
Current ride: '04 SAAB 9-5 Wagon. Doing the research on a new car, YF Sonata and new Santa Fe Sport are contenders.
rico567 is offline   Reply With Quote Quick reply to this message
Old 07-13-2012, 03:24 PM   #40 (permalink)
Mikemu's Avatar
The two hour trip is the killer. Synthetic? I'm always on the fence about that. I've seen engines go 300K+ on WalMart Supertech conventional oil changed every 3K miles.
