Questions about the Proximity key. - Hyundai Forums : Hyundai Forum
Old 06-25-2012, 02:19 AM   #1 (permalink)
2013 Sonata Ltd. White w/Nav.
JMONEY23 is an unknown quantity at this point
Default Questions about the Proximity key.
I've been wondering about this key ....
Is it rechargeable ?
Whats the slot for in the middle compartment ?
Why my dealer told me that it is rechargeable if its not ?
How long will the battery last ?
Any advice ?
Tnx.
2013 Hyundai Sonata Limited...Shimmering white w/Navigation package.
JMONEY23 is offline   Reply With Quote Quick reply to this message
Old 06-25-2012, 07:03 AM   #2 (permalink)
destro is an unknown quantity at this point
It is not rechargable. It takes a battery, just like common FOBs. The slot is used when the key lacks the power to transmit all the way to the push start. When battery is dead or almost dead, you plug it into the slot and it will work. It does not recharge the key. Your dealer told you it was because he doesn't know any better. The battery life will depend on your use. No telling. The car will tell you as is starts getting low.
destro is offline   Reply With Quote Quick reply to this message
Old 06-25-2012, 08:57 AM   #3 (permalink)
2011 sonata se
louky
If you ever need to use the center console slot to start it, you have to take the black part off and just use the key only, just fyi. I've had to use mine 4-5 times in two years when the car won't start because it keeps saying the key is not in the car for some reason. Keeps telling me to depress the brake although I am mashing it through the floorboard.
louky is offline   Reply With Quote Quick reply to this message
Old 06-25-2012, 09:40 AM   #4 (permalink)
FlameOut's Avatar
2012 Sonata 2.0T
FlameOut
On mine, the entire fob clicks and locks into place when used in the console.
FlameOut is offline   Reply With Quote Quick reply to this message
Old 06-25-2012, 09:42 AM   #5 (permalink)
Mikemu's Avatar
2013 Sonata replaced by: 2014 Azera Limited with Premium - Porcelain White w/Black interior
Mikemu is an unknown quantity at this point
Your brake switch must be on the way out which seems to be a common problem on this vehicle.
Mikemu is offline   Reply With Quote Quick reply to this message
Old 06-25-2012, 09:43 AM   #6 (permalink)
Mikemu's Avatar
My dealer also told me that with a weak battery, you can hold the FOB right next to the push start button and it should start.
Old 06-25-2012, 10:21 AM   #7 (permalink)
2011 sonata se
louky
hmm, i have put the whole fob in there and it still wont start, then i take the physical key out and push it in there and it starts. so that's why i assumed it had to be out of the case. i'll try it again next time it happens.
Old 06-25-2012, 10:22 AM   #8 (permalink)
2011 sonata se
louky
yeah, probably so. i was googling sonata fob after reading this thread earlier and i saw people talking about that problem. i wonder how long it's covered under warranty?
Old 06-25-2012, 10:38 AM   #9 (permalink)
Mikemu's Avatar
I would think that's a five year 60K mile item.
Old 06-25-2012, 11:28 AM   #10 (permalink)
BiGMERF's Avatar
2011 YF Sonata SE
BiGMERF is an unknown quantity at this point
Send a message via AIM to BiGMERF
I have had to use the center plug a few times when i blew the fuse changing bulbs. lol
BiGMERF is offline   Reply With Quote Quick reply to this message
