When to replace timing belt? - Hyundai Forums : Hyundai Forum
Old 03-23-2012, 08:57 AM   #1 (permalink)
Deadman
Default When to replace timing belt?
I have a 2011 2.4 Limited.
I was told on a different forum that the timing belts on these cars need to be replaced often and before they break and smash the valves.
My question is, are these interference engines?
When are you guys swapping the timing belts, or planning to swap them?
Thanks in advance!
Deadman is offline   Reply With Quote Quick reply to this message
Old 03-23-2012, 08:58 AM   #2 (permalink)
2011 Sonata SE-Indigo Blue Pearl
Brett L. is an unknown quantity at this point
I thought ours had a chain not belt??
Brett
*2011 Hyundai Sonata SE
*2012 Kia Sorento SX AWD
www.facebook.com/brett.lowenthal1
Brett L. is offline   Reply With Quote Quick reply to this message
Old 03-23-2012, 10:03 AM   #3 (permalink)
jdugan4859's Avatar
jdugan4859 is an unknown quantity at this point
It's a chain, not a belt.
jdugan4859 is offline   Reply With Quote Quick reply to this message
Old 03-23-2012, 10:27 AM   #4 (permalink)
Knightro2's Avatar
'12 Sonata GLS Pop Package; '12 Elantra GLS Pref Package
Knightro2 is an unknown quantity at this point
+1 we have a chain. No changing needed.
Some people are like Slinkies....not really good for anything but bring a smile to your face when pushed down the stairs.
Knightro2 is offline   Reply With Quote Quick reply to this message
Old 03-23-2012, 10:32 AM   #5 (permalink)
Originally Posted by Deadman View Post
I have a 2011 2.4
2.4L THETA GDI
No go on that,, THETA is chain
Yes
We not offering anything chain related to the engine,, keep clean iol in the engine all the time and chain wear be no concern
Thanks in advance!
Aluminum front cover with cam cover over top = chain.
Old 03-23-2012, 10:57 AM   #6 (permalink)
Deadman
Oh, better yet!
Thanks guys, you here so much BS and it gets you wondering.
Old 03-23-2012, 01:17 PM   #7 (permalink)
uilleann's Avatar
2012 Sonata YF, Limited
uilleann is an unknown quantity at this point
Are timing chains subject to stretching at all over time? I've heard this numerous times over the years, but I know they almost never break the way that rubber belts do. If they do stretch at all, would that warrant replacing them? And if so, how does one truly determine if/when a chain is stretched to a point warranting replacement?
uilleann is offline   Reply With Quote Quick reply to this message
Old 03-23-2012, 02:18 PM   #8 (permalink)
2011 Sonata GLS MT
Fox Mulder is an unknown quantity at this point
Timing chains in older overhead valve V8's and V6's were just a chain and two gears, those would stretch over time and with no way to compensate for it the timing would be affected.
Modern overhead cam engines with chains have tensioners (same as timing belts) which compensate for the chain wearing and stretching over time. As long as proper maintenance is followed the chain should last the life of the engine. Clean oil is important, the tensioner needs a supply of clean oil to operate properly. Dirty oil or sludge will cause it to stick.
Fox Mulder is offline   Reply With Quote Quick reply to this message
Old 03-23-2012, 02:33 PM   #9 (permalink)
uilleann's Avatar
Don't the gears and tensioners wear out along with the chain itself causing potential tuning problems as the components age? Or is that a myth?
Old 03-23-2012, 02:38 PM   #10 (permalink)
2011 Sonata GLS MT
Again with older ones yes. In these cars, just do regular oil changes and it will probably go to the junkyard with the original chain.
Some years back I had a twin-cam Saturn with a chain, they were actually notorious for chain tensioner failures when maintenance was neglected and the oil got low or dirty. I took good care of mine and when I got rid of it at 150K it was still running well with the same chain.
