Stereo turns on but no audio - Hyundai Forums : Hyundai Forum
Old 02-18-2012, 12:32 PM   #1 (permalink)
2011 Sonata SE
gerpolit is an unknown quantity at this point
Default Stereo turns on but no audio
Hey guys, hoping someone can help here. I have a 2011 Sonata with the NAV package, and this morning when I started the car I found that I have no sound coming from my speakers. Stereo powers up just fine, all controls including nav and bluetooth seem to be functioning perfectly, and yet I am getting no audio. Does anyone have any thoughts?
gerpolit is offline   Reply With Quote Quick reply to this message
Old 02-18-2012, 01:28 PM   #2 (permalink)
Xsolara's Avatar
drives White 2012 AZERA w/ Tech pkg....2013 Elantra GT
Xsolara is an unknown quantity at this point
Try removing the radio fuse for about 60 seconds then put fuse back in hopefully that will reboot the radio
Xsolara is offline   Reply With Quote Quick reply to this message
Old 02-18-2012, 11:37 PM   #3 (permalink)
2011 Sonata SE
Checked the fuses, unplugged for a bit, nothing, unhooked the battery for a bit, again nothing. Quite frustrating. Any other thoughts?
Old 02-19-2012, 12:43 AM   #4 (permalink)
REBLEVINS's Avatar
OWNED 2000 ELANTRA<> 2007 ELANTRA<> 2010 SONATA<> 2012 ELANTRA LTD<> 2013 SANTA FE SPORT
REBLEVINS is an unknown quantity at this point
It's sort of like when the ash tray gets full, you have to buy another car.
REBLEVINS is offline   Reply With Quote Quick reply to this message
Old 02-19-2012, 04:28 AM   #5 (permalink)
2012 Sonata SE 2.4L.......... 2000 Camaro SS
Doesn't the 2011 have a Mute button on the radio? Have you tried playing with that? Do you have any audio with blue tooth?
Dave-S is online now   Reply With Quote Quick reply to this message
Old 03-17-2012, 03:27 PM   #6 (permalink)
pgeneste
VERY simple to fix!! A cold reset or reboot of the radio, do this by pulling out the memory console fuse in the fuse box next to the steering wheel, (see storing your car for long periods in the battery section of your manual) left it pulled for an hour or two, then pushed it back in (have to use the key as the auto locks will not work when pulled) and all audio sound was restored. Only needed to reset my presets for XM radio and all good to go. Kinda like a Microsoft reboot fix. LoL Best regards to others. Phil
pgeneste is offline   Reply With Quote Quick reply to this message
Old 04-06-2012, 06:42 PM   #7 (permalink)
Drives Sonata YF Turbo
FootballYouBet is an unknown quantity at this point
SE 2.0T with NAV Dimension. Was driving down the street today listening to the radio when suddenly audio cut out completely. I thought it was the radio station gone silent but I changed to CD and IPOD and still got no sound. Volume controls worked still and showed level changes but got no sound. Pulled over. Shut off the car. Started it back up again and after the NAV/Stereo rebooted I got the sound back. Not happy about this with just 1,300 miles on the car.
FootballYouBet is offline   Reply With Quote Quick reply to this message
Old 04-06-2012, 07:56 PM   #8 (permalink)
Supporting Vendor
Rob@UNAVi's Avatar
Accent Elantra Sonata Tucson Genesis coupe Genesis sedan Azera
Rob@UNAVi is an unknown quantity at this point
Send a message via Skype™ to Rob@UNAVi
With the Factory Nav system you should also have an upgraded stock amplifier. Fusing may not be the same for it and there could be two causes for why it isnt working. If you have full function of the radio but no sound then it isnt the fuses for the radio but the fuse for the amp, you may need to refer to your owners manual for its location however you may need to consult your local dealership to find out where it is. The other possible issue is speakers most amplifiers have built in protection to prevent damage from the result of a grounded or blown speaker. If you had no problems with the speakers (rattling/buzzing) then you should be ok and it should be a simple fix. I have seen both issues with many different makes of cars so first check all fusing inside and outside under the hood. Good luck hope you solve the issue.
WWW.UNAVI-USA.COM OEM Integrated Navigation For Hyundai/KIA/ and GM vehicles. 1-855-558-6284
Rob@UNAVi is offline   Reply With Quote Quick reply to this message
Old 04-07-2012, 07:02 AM   #9 (permalink)
MikeyTG's Avatar
MikeyTG
There is a reset hole up near the CD slot that you can stick a pin in to reset the unit, maybe that will get it going again.
MikeyTG is offline   Reply With Quote Quick reply to this message
Old 02-16-2013, 07:45 PM   #10 (permalink)
Drives 2011 Sonata
Cocoa57 is on a distinguished road
Default No sound from radio
I'm having the same problem....no sound from radio. It was working fine and just stopped. Nav system and bluetooth are working, but no sound. Suggestions please!
Cocoa57 is offline   Reply With Quote Quick reply to this message
