keys in trunk - Hyundai Forums : Hyundai Forum
Old 02-12-2012, 11:37 AM   #1 (permalink)
sonata
skidley432 is an unknown quantity at this point
Default keys in trunk
Locked the keys to a 2011 sonota in trunk. Locksmith got side door open but trunk will not open with button inside. Any suggestions. Other set of keys 1500 miles away!
skidley432 is offline   Reply With Quote Quick reply to this message
Old 02-12-2012, 11:51 AM   #2 (permalink)
RedTurbo's Avatar
2011 Sonata 2.0 SE Turbo
RedTurbo is on a distinguished road
ouch ... can you pull the back seats down and crawl in?
RedTurbo is offline   Reply With Quote Quick reply to this message
Old 02-12-2012, 11:59 AM   #3 (permalink)
jdugan4859's Avatar
jdugan4859 is an unknown quantity at this point
The lock switch must be in the key only postion on the trunk. Gonna have to have the key lock picked, or break the back seat.
jdugan4859 is offline   Reply With Quote Quick reply to this message
Old 02-12-2012, 12:00 PM   #4 (permalink)
2011 Sonata GLS MT
Fox Mulder is an unknown quantity at this point
The seat releases are inside the trunk.
If the inside button release doesn't work, you might have flipped the lever on the trunk lock that disables the remote unlock and allows access only with the key.
It's also possible the button only works when the car has been unlocked with the remote, but I'm not sure about that. You may need to find a dealer nearby and have a spare key cut by the VIN.
edit- I was too slow, above reply was posted while I was typing.
Fox Mulder is offline   Reply With Quote Quick reply to this message
Old 02-12-2012, 12:07 PM   #5 (permalink)
sonata
Locksmith tried, no good
Old 02-12-2012, 12:08 PM   #6 (permalink)
sonata
Ok thanks
Old 02-12-2012, 12:38 PM   #7 (permalink)
blazeman's Avatar
2013 Sonata Hybrid Limited
blazeman is an unknown quantity at this point
This isn't what you want to hear... but I'm guessing it might be faster just have the spare overnighted
Bob
Current Hyundai: 2013 Sonata Hybrid
Past Hyundai(s) : 2011 HSH, 2006 Sonata, 2001 Elantra,
blazeman is offline   Reply With Quote Quick reply to this message
Old 02-12-2012, 02:36 PM   #8 (permalink)
2011 sonata
prestiege is an unknown quantity at this point
sounds like you need your keys over nighted 1500 miles away via fed ex, if the locksmith got the doors open, you can remove your rear dash, remove your 8" sub if you have one in the rear dash and reach in to pull the seat lever, if you dont have a sub, remove the plastic sub insert or punch a hole in it to reach the seat release
it scares me how after installing a sterieo system that took 3 hours you realize you can steal it in under 5 min
prestiege is offline   Reply With Quote Quick reply to this message
Old 02-12-2012, 09:55 PM   #9 (permalink)
gregd71's Avatar
gregd71
there is a trunk release button. if you could find a thin sturdy pole of some sort and stick it between the seats, you may be able to pop the trunk... unless your trunk is full of stuff
gregd71 is offline   Reply With Quote Quick reply to this message
Old 02-12-2012, 11:37 PM   #10 (permalink)
2012 Sonata SE-- 2013 Santa Fe LWB Limited
Dr.Gonzo is an unknown quantity at this point
Like said above, Fedex overnight would be a cheap alternative.
Is there someone that can get to your other keys?
Dr.Gonzo is offline   Reply With Quote Quick reply to this message
