"auto" Headlights Staying On - Hyundai Forums : Hyundai Forum
Old 07-26-2011, 10:34 PM   #1 (permalink)
blueanxiety
Has anyone experienced an issue with the automatic headlights staying on after the car is turned off and is in park?
I have about 1k miles on the car and I've noticed that in the evening, the headlights will not shut off after I park the car. This will happen maybe 3 or 4 times already, but it happened twice today. Is there something that I am not doing in order for them to shut off? I have been toggling them to "on" and then back to "automatic" in order for them to shut off. Is this a common issue?
Pardon me if this has been mentioned. I read a thread about accessories staying on - but my radio turns off fine, it's just the headlights that stay on.
blueanxiety is offline   Reply With Quote Quick reply to this message
Old 07-26-2011, 10:39 PM   #2 (permalink)
Hbk5585
QUOTE (blueanxiety @ Jul 26 2011, 10:34 PM)
Correct me if I'm wrong, but I think they stay on 90 seconds after the car is shut off. I believe this is an option that is turned on by default, but I think there is a way to change this, I think by holding down the TRIP button for 5 seconds, which brings a menu.
Is this correct?
Hbk5585 is offline   Reply With Quote Quick reply to this message
Old 07-26-2011, 10:39 PM   #3 (permalink)
brogers57
They are timed at 25 seconds. If I am not mistaken you can set these by holding down the trip Button while in park.
brogers57 is offline   Reply With Quote Quick reply to this message
Old 07-26-2011, 10:40 PM   #4 (permalink)
brogers57
QUOTE (Hbk5585 @ Jul 26 2011, 10:39 PM)
Is this correct?
You have different time settings that can be used.
Old 07-26-2011, 10:41 PM   #5 (permalink)
YF
Mod King is an unknown quantity at this point
QUOTE (blueanxiety @ Jul 26 2011, 07:34 PM)
The headlight delay is probably active and can be turned off using the settings displayed on the trip screen...you can look this up in the owner's manual and turn the delay off.
Mod King is offline   Reply With Quote Quick reply to this message
Old 07-26-2011, 11:54 PM   #6 (permalink)
13SonataScott's Avatar
With the switch in auto mode; If you shut off the engine and stay in the car, I believe the lights will stay on for 20 minutes. If you open and close the drivers door I think they go off 20 seconds later. If you set the alarm with the remote, pushing set twice, they go off right away. I may be off a little with the times, but I think that is the basic operation of it.
13SonataScott is offline   Reply With Quote Quick reply to this message
Old 07-26-2011, 11:56 PM   #7 (permalink)
blueanxiety
QUOTE (bkim @ Jul 26 2011, 10:41 PM)
Duh - that explains it. I was reviewing the menu settings this morning. I must of accidentally clicked it and selected it when I was viewing the options today.
Thanks!
Old 07-27-2011, 10:02 AM   #8 (permalink)
jbrams
QUOTE (blueanxiety @ Jul 26 2011, 08:56 PM)
Thanks!
The manual explains the standard times and (as above) how to change the setting. Basically, with auto-on, they stay on when you turn the car off for 30 seconds or until you arm the alarm (double press the lock button on your remote). If they are left "on" they stay on for 20 minutes then turn off automatically to save the battery from draining (the manual explains how to keep them on longer if you want).
So, yes, normal behavior.
jbrams is offline   Reply With Quote Quick reply to this message
