Front Wheels Are Free To Rotate - Hyundai Forums : Hyundai Forum
Old 06-02-2011, 07:12 AM   #1 (permalink)
2011 Sonata SE 2.4L (w/ sunroof only)
fotchow
Recently I was doing an oil change...had the front of the car jacked up and noticed something weird...I was able to rotate the front wheels with my hands with relatively minimal force...the transmission was in Park...the Sonata is a FWD car so the front wheels should be connected to the transmission and should be locked if the transmission is in Park...otherwise the car could potentially roll on an incline or decline if the parking brakes are not engaged...has anyone noticed this issue???
fotchow is offline   Reply With Quote Quick reply to this message
Old 06-02-2011, 07:37 AM   #2 (permalink)
RamKat's Avatar
RamKat
QUOTE (S_O_N_A_T_A @ Jun 2 2011, 07:12 AM)
When you turned the one front wheel, did the other turn in the opposite direction? If that is the case it is normal since the differential is not locked when the transmission is in parked , only the transmission.
You will see the same thing happening on the rear wheels of a rear wheel drive car when in park
RamKat is offline   Reply With Quote Quick reply to this message
Old 06-02-2011, 09:17 AM   #3 (permalink)
fotchow
QUOTE (RamKat @ Jun 2 2011, 07:37 AM)
Nope, both wheels are turning in the same direction...
Old 06-02-2011, 10:13 AM   #4 (permalink)
joeeey's Avatar
2013 Sonata Hybrid Limited 2007 Elantra SE
QUOTE (S_O_N_A_T_A @ Jun 2 2011, 09:17 AM)
Are you really sure?? They should turn in opposite directions due to the differential gears.
joeeey is offline   Reply With Quote Quick reply to this message
Old 06-02-2011, 10:18 AM   #5 (permalink)
theprodigy79's Avatar
2011 Sonata Limited 2009 Infiniti G37S Sedan 1988 Toyota Supra Turbo
theprodigy79 is an unknown quantity at this point
Test it out; put your tranny in park on a shallow incline/decline (driveway?) without the parking brake engaged and slowly lift your foot from the brake (otherwise the car may lurch)... If the car rolls without resistance, you have a pretty serious issue...
theprodigy79 is offline   Reply With Quote Quick reply to this message
Old 06-02-2011, 11:04 AM   #6 (permalink)
fotchow
hmm...now I'm not sure...I guess I'll check again this weekend...
Old 06-02-2011, 04:05 PM   #7 (permalink)
11yfLtd's Avatar
11yfLtd
If you really had it in park, I'd be willing to bet that the wheels were turning in opposite directions. It's perfectly normal for them to do so.
11yfLtd is offline   Reply With Quote Quick reply to this message
Old 06-02-2011, 04:57 PM   #8 (permalink)
Xsolara's Avatar
drives White 2012 AZERA w/ Tech pkg....2013 Elantra GT
Xsolara is an unknown quantity at this point
QUOTE (11yfLtd @ Jun 2 2011, 03:05 PM)
Something is not right ....... If the transmission is in park the front wheels should not move ... If the transmission is in neutral they would move in the opposite direction
Xsolara is offline   Reply With Quote Quick reply to this message
Old 06-02-2011, 06:07 PM   #9 (permalink)
sienna1's Avatar
2011 Sonata 2.4L Limited 2012 Veracruz GL FWD
QUOTE (Xsolara @ Jun 2 2011, 04:57 PM)
Both drive-shafts are connected to the transmission via the differential. The differential is made up of carrier gears (located at the end of the drive-shafts), ring gear (driven by the transmission) and a carrier gear (this links the ring gear to the carrier gears). The ring gear would be locked by the transmission (if not in neutral) but with both wheels off the ground, the wheels will turn in opposite directions due to the make-up of the mentioned gears. If one wheel was on the ground (or unable to turn) then it would be impossible or difficult (depends on the type of differential) to turn the free wheel.
sienna1 is offline   Reply With Quote Quick reply to this message
Old 06-02-2011, 08:31 PM   #10 (permalink)
ak969's Avatar
ak969
Here's a good video on how differentials work, this further explains why they spin in opposite directions.
http://www.youtube.com/watch?v=yYAw79386WI
ak969 is offline   Reply With Quote Quick reply to this message
