LinkBack | Thread Tools |
#1 (permalink) |
Just unscrew the "U" clamp, use a Dremel to make an oval hole. That way, you will be able to move the "U" inward and make you door close fermly. Remove material little by little with the Dremel and try to fit the screw frequently to achieve perfect fit together. When done, put blue Loctite on the screws and adjust carefully before tighting. Voilà!
So easy. Pictures on their way.... |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) | |
Drives 2013 Azera w/Tech
QUOTE (sp4772 @ May 28 2011, 05:19 PM)
2013 Azera Smoke Gray Black Graphite Interior Tech Package |
#3 (permalink) | |
QUOTE (jsmit86 @ May 28 2011, 06:22 PM)
Now mine just give the same solid feeling as the three others. |
#5 (permalink) |
doing that modification to the striker plate accomplishes nothing, if anything your able to slightly adjust the striker position a bit more and that's it.
2011 Sonata Limited Silver/Black leather with Nav. To many mods to list... |
#7 (permalink) |
2011 Sonata GLS MT
Yep all you've done is weaken the striker plate and make it more likely to loosen up in the future. You've also given the dealer a reason to refuse any warranty work to align the door.
#8 (permalink) | |
QUOTE (Fox Mulder @ May 29 2011, 02:03 PM)
#9 (permalink) | |
QUOTE (Smoke1991 @ May 29 2011, 11:25 AM)
#10 (permalink) | |
QUOTE (snapper41 @ May 29 2011, 01:54 PM)
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
