Esc Light Stays On - Hyundai Forums : Hyundai Forum
Old 03-21-2011, 11:18 AM   #1 (permalink)
cagilber
I've got a 2011 Sonata GLS and recently I've been having issues with the ESC light (not the OFF light) activating and staying ON until the car is restarted. I notice that it happens most when I'm doing low speed turns. I'm hoping I can catch it some day when I have time to make a stop into the dealership while it's illuminated. Does anyone else experience this issue? Could it be a result of improper tire pressure?
cagilber is offline   Reply With Quote
Old 03-21-2011, 11:24 AM   #2 (permalink)
Smoke1991's Avatar
Smoke1991 is an unknown quantity at this point
probably nothing with tire pressure, if the light stays on that means there is a fault in the system.. most likely a wheel sensor.
take it to the dealer, they it would be under warranty.
2011 Sonata Limited Silver/Black leather with Nav.
To many mods to list...
Smoke1991 is offline   Reply With Quote
Old 03-21-2011, 12:08 PM   #3 (permalink)
cripsy
QUOTE (Smoke1991 @ Mar 21 2011, 11:24 AM)
Yep, the manual states to take it to the dealer if the light remains on. They will fix it, this is what they do.
cripsy is offline   Reply With Quote
Old 03-21-2011, 04:48 PM   #4 (permalink)
jsmit86's Avatar
Drives 2013 Azera w/Tech
jsmit86 is an unknown quantity at this point
Another possibility is your brake pedal sensor switch. I had the same symptom prior to mine failing. (ESC Light coming on after cornering.)
The headache is that the car depends on the brake pedal sensor to allow you to start the car.
Mine was fixed quickly, and no issues after the fix.
By the way, if that is the issue, and the car won't start, you can over-ride by holding your start button for 30 seconds.
2013 Azera
Smoke Gray
Black Graphite Interior
Tech Package
jsmit86 is offline   Reply With Quote
Old 03-22-2011, 02:36 PM   #5 (permalink)
herr_howard
QUOTE (jsmit86 @ Mar 21 2011, 04:48 PM)
Since the OP has a GLS, it's a keyed ignition (no start button), but it's still a great tip for all of the SE/Limited/Turbo owners out there!
herr_howard is offline   Reply With Quote
Old 03-22-2011, 04:21 PM   #6 (permalink)
jsmit86's Avatar
QUOTE (herr_howard @ Mar 22 2011, 01:36 PM)
Oops! Good catch...
So.. just wondering.... if the brake pedal sensor goes bad on a GLS, does it prevent the car from starting?
(Do you still have to step on the brake to start the car?)
If so.. I wonder if holding the key to start for 30 sec does the same thing.
2013 Azera
Smoke Gray
Tech Package
Old 03-29-2011, 11:24 AM   #7 (permalink)
cagilber
Here is the issue they found.
http://usnews.rankingsandreviews.com/cars-...e-Lamp-Defect-/
Old 03-05-2012, 10:22 PM   #8 (permalink)
Drives 2011 Sonata GLS
WhitePearl is an unknown quantity at this point
Thumbs up ESC light stayed on and couldn't shift the car from Park to Drive
This same thing happened to me today. I called the dealer and they told me to use a screw driver or nail file; whatever fits in the little square to the left of the shifter, it says "shift lock release"; once you have the cover off, you have to stick the object down in the square and the shifter will release. This is just a band-aide, it will be going to the dealer on Friday to have it fixed. Hope this helps!
WhitePearl is offline   Reply With Quote
Old 09-04-2012, 10:37 AM   #9 (permalink)
Drives 2011 Sonata GLS w/PEP2
ryster is an unknown quantity at this point
Just had this ESC light issue with my 2011 GLS. Took it in, they found a stored DTC for the brake light switch/circuit. Replaced under warranty in less than 45 minutes.
No symptoms other than the ESC light. Since the GLS is a good old fashioned key start, you do not have to press the brake pedal to turn the key/start the car. My only concern would be if it would eventually prevent you from shifting out of park since you do need to press the brake to shift out of park.
Pacific Blue Pearl
Factory Cargo mat
205/65/16 Michelin Primacy MXV4 tires
ryster is offline   Reply With Quote
Old 09-05-2012, 04:33 AM   #10 (permalink)
2012 sonata
nhsonata is an unknown quantity at this point
May want to check but theres a good chance that while the esc light is on you wont have brake lights if it is a problem with the brake switch.
nhsonata is offline   Reply With Quote
