Interior Light Won't Turn Off - Hyundai Forums : Hyundai Forum
Old 10-15-2010, 11:42 AM   #1 (permalink)
jswinghammer
Hi,
I got my 2011 Sonata around two months ago and the interior dome light on the driver's side won't turn off. If you set the light setting to Door and open the door the passenger side light turns on and off when it's closed.
Any ideas on what might be causing this?
Thanks,
Jon
jswinghammer is offline   Reply With Quote Quick reply to this message
Old 10-15-2010, 11:51 AM   #2 (permalink)
Limited With NAV's Avatar
Limited With NAV
Both interior lights have a 'push' on and off feature........ So push the driver's side light 'in'....this should turn it 'off', and then it will operate as with the setting selected 'door'
Limited With NAV is offline   Reply With Quote Quick reply to this message
Old 10-15-2010, 01:04 PM   #3 (permalink)
jswinghammer
QUOTE (Limited With NAV @ Oct 15 2010, 10:51 AM)
The light never turns off when it's being pressed.
Old 10-15-2010, 01:45 PM   #4 (permalink)
Souks's Avatar
Souks
What the poster meant was the light may have accidentally been pushed in leaving it in the on position. So pushing it again will take it out of always on anf back to on when door opens.
Make sure all doors are closed when you push it so you can see if it actually turns off or not.
Souks is offline   Reply With Quote Quick reply to this message
Old 10-15-2010, 09:57 PM   #5 (permalink)
bsdlimited
QUOTE (Jon Swinghammer @ Oct 15 2010, 11:42 AM)
Hi,
Thanks,
Jon
I had the same problem with the rear dome light. I had to pull down on the trim ring around the light first, then push up on the light to turn it off.
bsdlimited is offline   Reply With Quote Quick reply to this message
Old 10-16-2010, 09:32 AM   #6 (permalink)
JohnLH's Avatar
Sonata Limited w/Nav - 2011
JohnLH
That is somewhat what I was thinking -
the "push up" switch may be stuck somehow.
I know you think you understand what you thought I said,
but I'm not sure you realize that what you heard is not what I meant!
JohnLH is offline   Reply With Quote Quick reply to this message
