Diy Cupholder Lights - Hyundai Forums : Hyundai Forum
Old 06-10-2010, 02:51 PM   #1 (permalink)
AccentGlowLED's Avatar
2011 Hyundai Sonata Limited
AccentGlowLED is an unknown quantity at this point
Red face
I created this mod originally as more of a functional mod than a fashion one, but it seems to work nicely for both. At night it was impossible to see where the cupholder holes were when placing drinks down, and I didnt want to scratch the center console so I decided to build my own. The goal was to be able to see the cupholder spaces, match the interior lighting, turn on and off with the other interior illumination, and look good.
Shout out to Glenn L. for keeping this mod alive. I now produce these kits and can ship them out to you for you to install. It’s easy! PM me to order or email me!
I also made a YouTube video detailing the entire process!!
Installation Instructions
2011+up Hyundai Sonata (all trims)
You may need the following tools:
• Plastic panel popper tool
• Small Flathead Screwdriver
• 3/16” Drill Bit (or larger)
• Silicone, Clear or Black
• Razor Blade
• Wire Strippers (I use something similar to the Irwin 2078300)
• Soldering Iron or another wire attachment technique (see end of instructions)
Disassembly:
-Begin by pulling off the silver-trimmed side panels on each side of the center console (highlighted in . Start near the end nearest to the back of the car (A) and use a plastic panel popper or your hands to carefully pry up (B1), then the panel will pull backwards towards the rear (B2).
A
B
C
-Depress the parking brake and move the shift level to the “N” position (you can do this by turning on the key –not starting the vehicle, or by using the small flathead screwdriver to lift the shift lock cover and press the button inside to allow the shifter to move without the key on) (D). You must then pull up on the shifter handle, a force of 50lbs or more may be required, and the shifter and the leather boot will lift off (E).
D
E
-The entire center piece from in front of the center console armrest pocket to the power outlets and aux jack is one single piece. (F) Open the center console armrest pocket and use your pry tool or your hands to begin lifting the center piece with the cup holders up (G). Once you get to the shifter that front piece including the power outlets and aux jack will pull forwards. Carefully lift up the piece and unplug the seat heaters (if available) (G) by depressing the tab on each side of the plug and then flip over and unplug the large white 26-pin plug attached to the power outlets and aux/USB jacks (I). Lift up and place the center console on a work bench.
F
G
H
I
Installation:
-First thoroughly clean inside each cup holder with an alcohol pad or similar de-greaser. Drill a 3/16” hole from the top of the center console slightly off center in each cup holder (so we don’t have to bend the LED wire as much as if it were a centered hole) (J). The actual holes drilled in the pictures are almost too close to the sides, use the indicated better hole placement (K).
J
K
-Run the LED wire through each hole and remove the covering from the double-sided tape on the back of each cup holder disc. Route the wire through each hole and place the disc down into the cup holder but do not press down yet, carefully center each disc and then press down firmly to secure.
L
-Flip the console upside down and dab some silicone into the hole that was drilled. This step is not necessary as next to no spills or condensation will make it down into the cup holder, but some people like the extra precaution. Next we are going to run the wires towards the front of the console to where the plugs for the power outlets and aux/USB jacks are. Use zip ties as needed keeping wires from hanging loose.
M
N
-Now we are going to wire in the power and ground for the LEDs. We need to use the power outlet plug with the yellow and black wires, and the white 16-pin plug going to the aux/USB (12-pin on navigation models). Take your razor blade and carefully cut back the fuzzy black covering on the wires going to the white 16-pin plug (12-pin on navigation models) and the power outlet with the yellow and black wires, so we can reach the wires. We will be using the black wire from the 2-pin power outlet plug and the blue wire (pin 8 on end) from the 16-pin plug (blue wire on the navigation models as well, but pin 6 on 12-pin connector not pictured. Pin 6 is on different end than pictured) (O,P).
O
P
-(Alternate wire attachment methods described at end of instructions) Now use wire strippers to side-strip both the black wire going to the power outlet plug and the blue wire in the 16-pin plug (12-pin on navigation models). Run both black wires to that black car wire and both red wires to the blue car wire. Strip back the LED wires, and then poke a hole through the center of both the black and blue car wires (Q). Take both black LED wires and twist them together and run them through the black car wire and wrap it around (R). Then solder them together (S). Tape up the connection and zip tie to secure (T). Do the same with the red LED wires attaching to the blue car wire (DISCLAIMER: A 1-3amp fuse is suggested in line with the red LED wires).
Q
R
S
T
-Make sure all of your wiring is secure and all exposed connections are covered and secured.
U
-Plug back in and replace the center console in the car (don’t forget the seat heaters) and turn on your headlights to test the LEDs. The remainder of the reinstall is the opposite of uninstall!
Alternate Wire Attachment Methods:
DISCLAIMER: Solder and tape is the most secure electrical connection, other methods described here are available for consumer convenience but will not be as secure of an electrical connection. Use at your own risk.
Option 1: Solder and Tape as described above
Option 2: Use the same technique without solder. Strip back wire with wire strippers and then just loop LED wires through car wire and tape, then secure with zip tie. This is sometimes called a “military splice” and is a perfectly acceptable way to install this particular wiring, if you tug on the wire the zip tie takes the pressure off of the actual connection, and the tape secures the connection itself.
Option 3: Scotch-Locks or “T-Taps”. These types of electrical connectors are very easy to use, and the amount of current going through them in this scenario is very small, but the problem arises with the electrical connection itself and whether or not the “T-Tap” successfully pierces the wire and then secures it. Problems can arise where the wire is broken by the “T-Tap” or the electrical connection becomes loose. This wire connection type is not recommended but can be used in a last resort by a consumer without access to wire strippers.
Check out my
Sonata Cup Holder Mod!
Elantra Cup Holder Mod!
I make these DIY install kits, PM me for details
Last edited by someguy; 08-05-2012 at 04:34 PM. Reason: updated by request of AccentGlow
AccentGlowLED is offline   Reply With Quote
Old 06-10-2010, 03:08 PM   #2 (permalink)
Cerberus451
Looks good, and nice walk through of the process.
Cerberus451 is offline   Reply With Quote
Old 06-10-2010, 03:09 PM   #3 (permalink)
NT2SHBBY
Send a message via AIM to NT2SHBBY
great job....not for the faint of heart though...
NT2SHBBY is offline   Reply With Quote
Old 06-10-2010, 04:42 PM   #4 (permalink)
rlipsey is an unknown quantity at this point
That is a very cool mod. I agree, not for the faint of heart. I don't usually have enough guts to tear my car apart. I figure I'll never get it back together again.
rlipsey is offline   Reply With Quote
Old 06-10-2010, 04:56 PM   #5 (permalink)
NT2SHBBY
QUOTE (Montag311 @ Jun 10 2010, 04:42 PM)
I always find myself with extra screws when I take things apart and then put them back together.
Old 06-10-2010, 05:44 PM   #6 (permalink)
glenn716's Avatar
2013 Hyundai Sonata Limited Turbo, harbor grey.
glenn716 is an unknown quantity at this point
Geez, that is amazing. I only wish I could do stuff like that but I have no wiring skills or the cojones to do it. Well done. I have enough skill to probably put on a set of mud flaps.
Goodbye 2011 Sonata SE. RIP. You were a good car. Thanks for the memories.
glenn716 is offline   Reply With Quote
Old 06-10-2010, 05:53 PM   #7 (permalink)
Getting it back together is the easy part!
And thanks guys, it took a bit more work and time than I had planned but turned out great and it feels a lot better doing it yourself than buying it from China
Check out my
Old 06-10-2010, 07:16 PM   #8 (permalink)
Quigley21's Avatar
2011 Sonata LTD
Quigley21
Love the idea.....
But I will have to read this over a few times before I may ( I did only say MAY ) get the cahones to try it.
I would like the mod though,,, neat idea......
Rebadged Trunk, Replaced Stock Horn, OEM Mudflaps, 35% Window Tint, Chrome Fog light Molding, Chrome Tail light Molding, Xenon Supply HID's 4300K, All LEDS All Around, Weathertech floor and Cargo Liners, LED Bumper Reflectors, LED Sonata Door Sills, Illuminated Gas / trunk Switch, LED Footwell Light Kit
Quigley21 is offline   Reply With Quote
Old 06-10-2010, 07:40 PM   #9 (permalink)
ThePill's Avatar
ThePill
Iceberg802 great job! You really put together an excellent easy to follow DIY project. Hyundai are you seeing this? Get cracking on incorporating Iceberg's illuminated cup holder design for the rest of us!
ThePill is offline   Reply With Quote
Old 06-10-2010, 07:51 PM   #10 (permalink)
TheMoose
Looks factory! Nice job. I kinda wish you would have taken a picture of the shifter area with the cover off just so I can see what it look like
Now hurry up an install those halo rings inside the headlights
Edit-Forgot to ask, how did you know those wires you spliced into had power when you turn the headlamps on? I guess you back probed the wires? The current schematics suck.
TheMoose is offline   Reply With Quote
