5w-20 Or 5w-30 Oil? - Hyundai Forums : Hyundai Forum
Old 05-11-2010, 03:05 PM   #1 (permalink)
osrk
My first oil change is coming up. The hyundai manual recommends that you use 5w-20 but says if not available you can use 5w-30 too. I think that 5w-30 is the way to go. 5w-20 is way to thin. Look at the data sheets at the end of these pages and compare them
5w-20
http://www.amsoil.com/storefront/xlm.aspx
5w-30
http://www.amsoil.com/storefront/asl.aspx
The 5w-30 is stated to last 25,000 miles while the 5w-20 is only stated to last about 7500 miles. I think 5w-20 is way to thin to provide protection and is sacrificing engine wear for a 1% increase in mpgs. Particularly important I think for a GDI engine is the Noack Volatility test, the 5w-30 is ~30% better vaporizing a lot less oil. Hyundai gives you the choice in the owners manual and I do not think the minuscule boost in mpgs is worth the engine damage or wear.
What do you guys think?
osrk is offline   Reply With Quote Quick reply to this message
Old 05-11-2010, 04:32 PM   #2 (permalink)
w9nwrwi
QUOTE (osrk @ May 11 2010, 02:05 PM)
5w-20
5w-30
I think I will continue on with my Pennzoil Ultra 5W-20.
yes, yes, I know its expensive. $28 for a 5 gallon jug at Wally-World.
Took the car in for oil change to my dealer at 1000 miles, showed him the Ultra, no problem. Used the Original Equipment Manufacturer Hyundai filter.
I suppose if I was living in a very hot climate I might consider 5W-30. If I keep to the maintenance schedule based on my driving I have absolutely no qualms
about premature "engine damage or wear."
Am I worried about seeing/not seeing a 1% increase in fuel MPG? Nope, some lab might but I am not.
I will not go 25,000 between changes, will stay with the 3500 in severe driving, based on Wisconsin winters and most trips short, less than 20 miles. Yep, I know, possible I am throwing a few bucks down the drain with such a short interval change based on the type of oil. Some folks still like cigarettes at 10 bucks pack! Whatever pops your circuit breaker.
Use a good quality oil of your choosing and press on. Now if you really need to get into it: http://www.bobistheoilguy.com/cms/
Lots of fun reading there and opinions all over the place.
Happy Motoring!
w9nwrwi is offline   Reply With Quote Quick reply to this message
Old 05-11-2010, 05:01 PM   #3 (permalink)
EL'ation
QUOTE (osrk @ May 11 2010, 03:05 PM)
5w-20
5w-30
Amsoil 5W-20 is formulated differently than its 5w-30. The life expectancy has nothing to do with the viscosity of oil.
Those two oils are in two different classes.
5W-20 was created for better gas mileage originally for cars that take 5W-30. And it saved tax for manufacturers in the US (CAFE). It of course caused more wear to the engine.
But I don't know that applies to the Sonata since they may have developed the engine around 5W-20. That case, 5W-30 would be too thick.
I would look into Korean owner's manual and see what is recommended there. They don't have the CAFE law, so they would recommend what's best for the engine.
EL'ation is offline   Reply With Quote Quick reply to this message
Old 05-11-2010, 06:23 PM   #4 (permalink)
bobad's Avatar
bobad is an unknown quantity at this point
Send a message via MSN to bobad
5w-20
5w-30
Depending on your winters, I agree 5w20 is thin, and possibly compromises maximum protection in hot weather. I suppose the
water-thin oil is recommended to help fleet gas mileage.
On the other hand, 25000 mile oil is over kill if you change it at 7500mi, the maximum change interval for normal service.
-=Bob A.=-
bobad is offline   Reply With Quote Quick reply to this message
Old 05-11-2010, 07:12 PM   #5 (permalink)
tCizzler is an unknown quantity at this point
QUOTE (w9nwrwi @ May 11 2010, 04:32 PM)
..... I e-mailed Pennzoil with my Make, model, engine type. No problem they say, Ultra a good choice.
So you asked Pennzoil if their oil was good for your car, and they said yes?? That' a surprise lol.
tCizzler is offline   Reply With Quote Quick reply to this message
Old 05-11-2010, 07:20 PM   #6 (permalink)
w9nwrwi
QUOTE (tCizzler @ May 11 2010, 06:12 PM)
The man asked what members thought, I told him my take on it.
Can you contribute something to his question??
Old 05-12-2010, 09:03 AM   #7 (permalink)
Blue07's Avatar
Blue07
What defines too thick? At 212*F, the 20w is 8.5 cSt and the 30w is 10.8cSt. At 104*F, the 20w is 45 cSt and the 30w is 60.7cSt. (That's about 5 times thicker.) At 20*F or 30*F, both oils are probably ten times that thicker than that. Compared to a winter start, the 30w (10.8 cSt) is still super thin. If someone worries about 2-3 cSt at operating temperature on a 9 cSt oil, they must totally freak out at the thought of a winter's cold start when even 0w oil is probably in the 100cSt area. It's all a matter of perspective. I can't see how 30w oil can hurt anyone's engine if they all survive daily cold starts.
Blue07 is offline   Reply With Quote Quick reply to this message
Old 05-12-2010, 09:11 AM   #8 (permalink)
jng34c's Avatar
jng34c
Hahaha... good point
QUOTE (w9nwrwi @ May 11 2010, 06:20 PM)
"No other success can compensate for failure in the home." - David O. McKay
jng34c is offline   Reply With Quote Quick reply to this message
Old 05-12-2010, 10:12 AM   #9 (permalink)
thehun
My personal experience with 5w20 will never ever in the world will be put into any of my cars...also in your owners manual 5w30 is approved to be used anyways at the same temp ranges. It cost my Mustang to have a blown engine (it was covered under warranty but what a hassle to go through)
Also, remember that this is a Direct Injected engine, you need an oil that will not "blow-by" or burn off so that it keeps the intake valves as clean as possible.
I dont know if you guys have noticed but a car running with dino oil, after about 60K miles you are going to see slug and deposit where you put your oil in. Reason for that is actually dino starts burning and sludging after about 2K miles. Dino has wax which creates the deposits.
The only reason you should ever change your oil at 3700 miles is if all you do is stop and go traffic, or live in the coldest temps throughout the year. 7500 miles is a good milestone to change oil. Whether you use AMSOIL or not, make sure that you do use a good-high quality synthetic to protect your direct injected motor. I know hyundai has done a great job preventing deposits on intake valves but it is just the design of DI engines.
The last thing you want to be cheap at is your motor oil.
FYI AMSOIL does make a filter when I cross referenced purolator, i believe it is eo20.
If you have any questions about amsoil, just shoot a pm to me...I am an amsoil dealer.
Also if you change your own oil, make sure you keep all your receipts and a log book of somekind for warranty purposes.
2011 Sonata SE
BLACK ON BLACK
AMSOIL- www.innovativeoils.com
thehun is offline   Reply With Quote Quick reply to this message
Old 05-12-2010, 03:43 PM   #10 (permalink)
wbw
wbw
I've got an '03 Honda Accord with 100,000 miles on it now and have used 5W-20 as speced for that motor from day 1. It runs as well as the day I bought it. Got an '07 Scion tc with 40,000 miles and it runs great on 5W-20 as speced. I would not be afraid to use the oil specified by the manufacturor. Especially in a car that the company is going to warrany the powertrain for 10 / 100,000. I don't think Hyundai is going to risk their motors with an oil that is not up to par. Of course the oil was originally speced for fuel mileage purposes, but personally I think that today's name brand oils, and especially synthetics, are up to the task of protecting the engine.
Just my 2 cents. Your opinion may vary.
wbw is offline   Reply With Quote Quick reply to this message
