LinkBack | Thread Tools |
#1651 (permalink) |
2012 Sonata Limited 2.0T
My XS 6000k is up and working! Think I had the connector on the ballast flipped. They look sweet! I do want to get a set of 4300k to compare, there is a hint of blue that I'm not crazy about.
How many of you adjusted your lights higher? I'd like to have my lows go a little farther.
2012 Radiant Silver Sonata Limited 2.0T Built 8/31/11 Mods: Spoiler, Mud Guards, Clear Bra, V1 Hardwire 27% Tint, XS 6000K HIDs, PrecisionLED 6000K everywhere |
| Sponsored Links | |||
Advertisement | |||
#1652 (permalink) |
2011 Sonata GLS -Radiant Silver
LOOKING FOR HELP- Xenon HID 2011 Sonata
Hello new to the forums, I have a 2011 Sonata GLS, I want to install HID's never done it before but think I can do it. I've been reading up on them and watching how to videos on YouTube. Seems not to difficult. My only problem is cant find them, or the right kit (don't know exactly what kit or what I need) From my research I think I want the 8000k (it's like a light blue) Looking on eBay I think I can get them for around 85$ Thank you MUCH! Looking forward to the replies Plasti dipped the factory wheels and I love it |
#1653 (permalink) | |
Drives Sonata YF2.0
#1654 (permalink) | |
2011 Sonata GLS
Pearl white
6000k Lows and Fogs, Retrofit Blazer Projector fogs, Led Fog DRL strips, Led everything, clear door lens, inner taillight mod, Luxgen badges, HP Black 05 Tint, Leather seatcover, Mobis mudflaps, Rear diffuser, Rearview mirror backup camera, Rear bumper Led reflectors, led footwell lighting, under-mirror led puddle lights, Paddle shifters, UR Strut Bar, Injen SRI. |
#1655 (permalink) |
Modification Of The Hid Bulb Question
Above Link references doc_aa's Picture in an older Apr '11 Thread about the Bulb's Ceramic "pole" being (usually) default-installed in the 12 o'clock position (because of the Bulb's Tab location) and the NEED for the "pole" to Insert at the 6 o'clock position via Cutting a New tab / Shadow disappears. XenonSupply is supposed to (NOW) be Modifying Bulb's FOR YOU, so I'm confused about your Shadows. Read the above Thread some and post back if more requ'd.
2011 Limited - Pacific Blue NAV v05.04.13 XS 4300K Prem Slim HID FormulaOne Pinnacle 35 Tint Michelin Primacy MXM4 Husky Floor-Trunk Liners Built 7/2/10 Politicians and Diapers Need Changing For the Same Reason |
#1656 (permalink) |
Drives Sonata YF2.0
Original Philips H7 6000K HID in original position. Black shadow could be seen obviously. AFTER TURN.jpg After turn thr return rod face down, no more shadow ans look brighter. 6000K HID VS LED.jpg My genuine Philips H7 6000K bulb (Made in Germany) look a bit yellowish compare to the 7.5W super bright LED. Thanks for those who share the valuable experience here how to remore the shadow in H7 bulb. Really help a lot. Happy retrofit..
#1657 (permalink) |
Does the H7 6000k bulb do anything at night when using your brights? Or is it useless?
#1658 (permalink) |
Had my first oil change today at the dealer since installing my HIDs. They checked the all of the lights when I pulled her in, didn't say anything about the HIDs that were looking mighty fine.
Got bent over on an air and cabin filter, which I approved thinking it was only going to be $50. $10 each to install. With tire rotation ($18), I was out the door for $100. Robbery! At least I took advantage of their coffee and cinnamon rolls! lol
#1659 (permalink) |
Installed the 4300k bulbs from XS. Don't like them. Went back to 6000k.
I think the 6000k bulbs produce better light and look much better. The 4300k looked almost stock, maybe a bit whiter. Anyone else see some slight shadows? I see them with both bulbs. Not the telephone pole shadows, just the light is a little different a few feet in front of the car.
#1660 (permalink) |
The New XS.com Install video talks of the (driver-side) H7 Connector Wiring being BOTH YELLOW (my '11 Ltd's are, of course, Green) with NO POLARITY indicated. The HID driver-side bulb Spaded Wires are, therefore, inserted into the Connector on a Try & Test later basis.
Is it that simple? No light, so you remove Dust cap and Reverse the Spades in the Connector? Nobody's mentioned any problem and I know everybody's not guessing Pos/Neg correctly every time. Any additional experiences to suggest what other key error(s) might Net No Lights other than good Power/Ground connections? Looking forward to this! Many Thanks!
2011 Limited - Pacific Blue NAV v05.04.13 XS 4300K Prem Slim HID FormulaOne Pinnacle 35 Tint Michelin Primacy MXM4 Husky Floor-Trunk Liners Built 7/2/10 Politicians and Diapers Need Changing For the Same Reason Last edited by craigos26; 11-30-2012 at 07:14 PM. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
