Bleeding air from the cooling system - Hyundai Forums : Hyundai Forum
Old 12-19-2012, 02:57 PM   #1 (permalink)
mladen_i20's Avatar
Drives i20 1.25i
mladen_i20 is an unknown quantity at this point
Default Bleeding air from the cooling system
Is there any air bleeder screw on the hyundai i20 (1.25i)? tomorrow I'll buy a red shell antifreeze (G12). And I intend to replace it tomorrow. Is there any protection under the radiator that must be removed in order to gain the cooling mixture bleed screw?
Hyundai i20 1.25 city star equipment package
mladen_i20 is offline   Reply With Quote
Old 12-21-2012, 02:14 AM   #2 (permalink)
sierra01
Usually any air trapped in the system makes its way up to the header tank doesnt it?
sierra01 is offline   Reply With Quote
Old 12-21-2012, 03:41 PM   #3 (permalink)
mladen_i20's Avatar
Drives i20 1.25i
The air is always moving up, but if the hose is folded so that its tip does not have an opening, air will remain trapped.
Old 12-22-2012, 04:04 AM   #4 (permalink)
sierra01
I wonder if he's talking about draining the system, you always get air trapped in it then.
Old 12-22-2012, 02:40 PM   #5 (permalink)
mladen_i20's Avatar
Drives i20 1.25i
Yes, ok
Today I dropped the coolant out through the sink faucet, but then come out less than 3L. I took off my reservoir cap and radiator cap. How to squeeze the remaining 1.1 liter? The technical data says that there are 4.1 liters of coolant mixture in i20 1.25
Old 12-26-2012, 01:22 PM   #6 (permalink)
mladen_i20's Avatar
Drives i20 1.25i
Still no answer?
Old 12-26-2012, 03:39 PM   #7 (permalink)
Bianco's Avatar
2013 Elantra GLS 6MT
Bianco is an unknown quantity at this point
To get the remaining coolant out there should be a drain bolt on the side of the engine block. Usually it's a brass bolt. You'll never get every single drop of coolant out of the system when draining.
2013 Elantra GLS 6MT in Shimmering White. "aka Bianco"
Mods: 20% Llumar Tint, Custom Intake System, Colour Matched Splash Guards, Painted Calipers, Rear Diffuser, Custom Axle-Back Magnaflow Exhaust, 18" Mazda RX-8 Rims finished in Hyper Silver and a Baby Seat....
Coming soon: Component Speakers and a 10" Sub.
Bianco is offline   Reply With Quote
Old 12-26-2012, 04:59 PM   #8 (permalink)
mladen_i20's Avatar
Drives i20 1.25i
Thumbs up Thanks
Thanks, I will try to find that bolt on the engine block. You will also have to be aware that not everything can come out.
