Faults With I20? - Hyundai Forums : Hyundai Forum
Old 09-01-2009, 05:05 PM   #1 (permalink)
KDC
KDC
like in the i10 forum, i wanted start any issues and faults post with the i20........ over here
for example, just reading over in the parkers reader reviews that some peoples windscreens have cracked, stereos not working etc....
anything else to look out for those have got new cars so far...?
KDC is offline   Reply With Quote Quick reply to this message
Old 09-02-2009, 07:01 PM   #2 (permalink)
Anisto
Send a message via MSN to Anisto
leaking rims is one problem, (this is only for 1.2L) if the car is hard to put in reverse(even if you clutch twice or put it in another gear) there is 2 bolts that can be tightened or a mechanism that can be replaced.
Minor problems, but the car is new and there is always some problems in the beginning.
both problems should the Hyundai car dealers/workshops be noticed about.
Anisto is offline   Reply With Quote Quick reply to this message
Old 09-05-2009, 03:44 AM   #3 (permalink)
eifionlewis
QUOTE (Anisto @ Sep 3 2009, 12:01 AM)
Would this be the same for having trouble getting it into 1st gear?
eifionlewis is offline   Reply With Quote Quick reply to this message
Old 10-08-2009, 01:58 PM   #4 (permalink)
Dark_Dreams
QUOTE (Eif @ Sep 5 2009, 08:44 AM)
I take it you've also had problems with 1st gear Elf. Did you get it sorted?
Has anyone else had problems with getting 1st gear?
It's only my first week with the car so I'm hoping maybe some of my issues work themselves out.
So far...
1. First gear is sometimes tricky to get into. Not everytime, but often enough to be bloody annoying.
2. The windscreen heater seems pathetic. I sat for 10 minutes this morning waiting for all the moisture to clear from the inside of the window (which also makes me wonder how the **** it got there...!?!). I eventually ran out of patience and went inside to get a cloth to wipe the screen (not ideal!). I'm going to test this on a longer run at the weekend.
3. The Air Con comes on everytime the fan is on. Not really a fault, just annoying to have to turn it off everytime I start the car or turn on the fan.
Dark_Dreams is offline   Reply With Quote Quick reply to this message
Old 10-08-2009, 04:00 PM   #5 (permalink)
Drives i20 1.2
SilentSpring
QUOTE (Dark_Dreams @ Oct 8 2009, 07:58 PM)
So far...
1. First and rear gear are sometimes a bit tricky. I have 2000km and it seems to be better now.
In the beginning it was almost once a trip, but now it's very rare.
2. You need to put the Airco on for that, in a few seconds the moisture is gone.
My car
SilentSpring is offline   Reply With Quote Quick reply to this message
Old 10-08-2009, 04:41 PM   #6 (permalink)
rodderstrotter
QUOTE (Dark_Dreams @ Oct 8 2009, 06:58 PM)
It should only do this when demist is selected.
rodderstrotter is offline   Reply With Quote Quick reply to this message
Old 10-09-2009, 08:35 AM   #7 (permalink)
Dark_Dreams
QUOTE (rodderstrotter @ Oct 8 2009, 09:41 PM)
You're quite correct rodderstrotter - any other setting and the air con goes off. Demister is about the only setting I ever use on a car fan heater, will need to consider using something else.
QUOTE (SilentSpring @ Oct 8 2009, 09:00 PM)
Thanks SilentSpring.
Fingers crossed it clears after a bit of distance.
I'll try it with the aircon on next time - screen was clear this morning anyway so I couldn't test.
Old 11-06-2009, 02:01 PM   #8 (permalink)
KDC
KDC
i have a slight rattle, in the left rear area, very gentle tapping of metal. any ideas on what that might be??
Old 11-06-2009, 03:45 PM   #9 (permalink)
BristolSteve
QUOTE (KDC @ Nov 6 2009, 07:01 PM)
Check the seat belts are fully retracted - i had one having a little wobble at times as not fully home and was very annoying.
BristolSteve is offline   Reply With Quote Quick reply to this message
Old 11-07-2009, 12:41 PM   #10 (permalink)
KDC
KDC
cheers i ll take alook, if not i ll pop into the dealers, they might know what it is, just annoying
