Hyundai GDS diagnostics - Hyundai Forums : Hyundai Forum
 1Likes
  • 1 Post By AUTOSPARK
post #1 of 9 (permalink) Old 06-15-2017, 12:05 PM Thread Starter
Hyundai Tucson 2,0 CRDi 185 Premium aut. 4WD pano Hyundai i10 Go Sport 1.0 2015
Quoted: 12 Post(s)
HappyUser is an unknown quantity at this point
Hi all
Since technical forums are closed, I will ask my question here instead...
I wonder why I only have limited options in my GDS software.
Am I looking the wrong places in my software?
I need to gain acces so I can switch "bad" bulb indication off, so I can install led turn signal light...
Are there a forum, where I can discuss Hyundai GDS software, that isn't closed?
Sendt fra min ZUK Z2121 med Tapatalk
HappyUser is offline
post #2 of 9 (permalink) Old 06-15-2017, 12:19 PM
newtech's Avatar
Drive 2011 Tucson Ltd., 2014 Subaru XV AWD, Honda Prelude, Honda CRV
Quoted: 18 Post(s)
newtech is an unknown quantity at this point
Hi "Happyuser"
According to your profile, are you in the right forum, if not, let me know then I can transfer your question to "i10" or i20" forum.
newtech is offline
post #3 of 9 (permalink) Old 06-15-2017, 02:01 PM Thread Starter
Quoted: 12 Post(s)
Originally Posted by newtech View Post
Hi "Happyuser"
Thank you, but this is regarding 2016 Tucson, or more precise GDS software
post #4 of 9 (permalink) Old 06-15-2017, 03:05 PM
dougmcp's Avatar
2013 Genesis 3.8 Tech Pkg, 2003 VW Passat GLX Variant 2.8, 2005 Ford F250 FX4 Lariat 6.0 Diesel
Quoted: 99 Post(s)
dougmcp is an unknown quantity at this point
Not trying to hijack your thread but I have a ton of questions as well about GDS, is that verboten on this forum? If not where would I find the link?
Some days you're the statue and some days you're the pigeon, I'd rather be the pigeon.
dougmcp is offline
post #5 of 9 (permalink) Old 06-16-2017, 02:17 AM Thread Starter
Quoted: 12 Post(s)
Its ok, i'm stuck here anyway - nobody want's to answer GDS questions for some reason...
post #6 of 9 (permalink) Old 06-16-2017, 11:34 AM
dougmcp's Avatar
Quoted: 99 Post(s)
Regarding your bad bulb issue, install a resistor in series with the bulb.
Something like these will work: https://www.ebay.com/i/252526203117?chn=ps&dispItem=1
As far as the GDS goes, I will be ordering one in Aug/Sept like this: OBD2 GDS VCI Diagnostic Tool for HYUNDAI with Trigger Module Firmware V2.02 | eBay
I need to change some parameters in my car from metric to US.
dougmcp is offline
post #7 of 9 (permalink) Old 06-16-2017, 11:51 AM
AUTOSPARK's Avatar
Hyundai Getz 1.5 CRD (D4FA)
Quoted: 1069 Post(s)
That's because nobody has answers to give you. I don't use GDS myself but I don't think it can do what your want. Hyundai cars aren't like VW/BMW where you can activate different module options in software. The bulb failure circuit that is causing your hyper flash is a hardware feature of the turn signal relay. AFAIK, you can't just turn it off via the OBD connector. I did post a while back how to modify a standard Hyundai flasher relay to make it work with LED lamps...see below. It's a bit more complicated on your car though because the turn signal relay is now built into a larger relay module, but I suspect the same modification will still work on that too if your brave enough to hack it.
Regards.
Scottie.
Killing Hyper Flash - Flasher Relay Mod
dougmcp likes this.
AUTOSPARK is offline
post #8 of 9 (permalink) Old 06-16-2017, 02:29 PM Thread Starter
Quoted: 12 Post(s)
I get it and great guide btw.
- I read it somewhere else in forums, that newer Tucson and Elantra was able to turn off this "feature" in GDS... That is why i'm looking for solutions, regarding this
post #9 of 9 (permalink) Old 06-23-2017, 09:44 AM Thread Starter
Quoted: 12 Post(s)
I did not get the resistors to work, it hyperflashes anyway...??
