Dashcam wiring - Page 2 - Hyundai Forums : Hyundai Forum
 7Likes
post #11 of 23 (permalink) Old 03-20-2017, 10:53 AM
navein's Avatar
Drives 2016 Hyundi Tucson Drives 2009 Suzuki Swift
Quoted: 39 Post(s)
navein is an unknown quantity at this point
Send a message via Skype™ to navein
Hi
I have used the same cig lighter port for powering my dash cam. I have ran the wire through the A piller and goes to the ceiling and you can remove the covers of the mirror and run it to the camera.
I will make a video of how to remove the A Piller covering. Its very easy. Please note that i do not have air bags in my pillers.
File Type: jpg 14900186390931290072226_1490018721142.jpg (123.8 KB, 38 views)
File Type: jpg 14900188132371568466431_1490018850588.jpg (80.9 KB, 35 views)
File Type: jpg 1490018949749134498964_1490018999546.jpg (127.3 KB, 37 views)
File Type: jpg 1490019012596383244754_1490019032309.jpg (110.1 KB, 34 views)
File Type: jpg 1490019043954102128859_1490019094229.jpg (88.8 KB, 33 views)
navein is offline
post #12 of 23 (permalink) Old 03-20-2017, 11:04 AM
navein's Avatar
Quoted: 39 Post(s)
Here is the link to the video.
https://youtu.be/GuHSQDwLcn4
navein is offline
post #13 of 23 (permalink) Old 03-20-2017, 02:56 PM Thread Starter
Dare4x4's Avatar
Drives 2016 Tucson 1.6T-Gdi 4WD, 2007 Zastava Koral In 1.1, 2002 Lada Niva 4x4 1.7
Quoted: 14 Post(s)
Dare4x4 is an unknown quantity at this point
I think that I also don't have an airbag in A-pillar because there is "Airbag" logo on the B-pillar above seat belt.
Thanks for video.
Dare4x4 is offline
post #14 of 23 (permalink) Old 03-21-2017, 06:16 AM Thread Starter
Dare4x4's Avatar
Quoted: 14 Post(s)
Camera is installed. Nothing is visible, except power supply in the left power outlet. I can confirm that airbag is inside A-pilar. I hope that I will never use it and that wire for camera will not affect its functionality.
When ignition is off, camera shuts down and I think that my battery is safe...
navein likes this.
Dare4x4 is offline
post #15 of 23 (permalink) Old 03-21-2017, 10:14 PM
2016 Tucson - Ultimate Ash Black - Tan Interior 2015 Genesis Sedan - Technology Caspian Black - Tan
Quoted: 46 Post(s)
jusungchai is an unknown quantity at this point
I wrote this over a year ago and its probably hidden somewhere so I will rewrite for new comers.
Hard wiring dash cam to your fuse box:
I used the Power Magic Pro by Blackvue along with Blackvue dashcam (I recommend getting this kit and you can pick any other dashcam you want as long as it has cigarette plug). The purpose of this kit is so that you can set it to auto shut off power to dashcam when battery drops below a certain voltage. (Great for parking mode when ignition is off).
Now to the fuse box, I pluged in the power source (when car ON) to rear wiper fuse. When car OFF, I plugged it to power seat switch fuse. There is one common ground which I unbolted a screw slightly near the fuse box is (car body) and screwed it back tight.
For those asking if you really need those add a fuse tab, I personally did not use it. I just took out the fuse and wrapped the wire around and plugged it back in.
I installed this probably October 2015 and have not yet had a problem.
jusungchai is offline
post #16 of 23 (permalink) Old 03-22-2017, 02:02 AM
lovemysantafe's Avatar
Drives: 2012 Elantra Limited
Quoted: 70 Post(s)
I've had a dash cam tapped off my power outlet fuse for over a year now with no issues. Keeps my power outlets open and ready to use and completely hides the dash cam installation.
Quick & Easy Dash Cam Installation Kits for Sale | Made in the USA
twospirits likes this.
Andrew
Titanium Gray / Gray Leather
lovemysantafe is offline
post #17 of 23 (permalink) Old 03-28-2017, 09:13 PM
2016 Tucson Premium 2.0 FWD (Black) 2013 Sonata SE (GONE)
Quoted: 85 Post(s)
daviiiiiid is an unknown quantity at this point
As someone with absolutely no confidence in my skill to be able to hardwire this to anything, I currently have this setup.
RED is VISIBLE wiring, YELLOW is hidden wiring, so under weatherstrip, inside glove box..., etc etc.
I dont seem to have airbags in my A Pillar and didnt figure out how to remove it, even after watching all videos. Pulling does nothing
Also once I'm down the right side, I have no idea from wher I should start coming out and pass the cable.. Right now I actually have it just dive in the glove box and come out on either sides.. Which doesn't seem ideal.
Anyone with suggestions?
daviiiiiid is offline
post #18 of 23 (permalink) Old 03-28-2017, 10:07 PM
twospirits's Avatar
2016 Hyundai Tuscon FWD Ultimate Carib Blue
Quoted: 70 Post(s)
twospirits
I like that idea.
btw, nice seeing you here Andrew.
TS out
<--- Members, Please fill in your location, the vehicle you drive (Model year and Trim) and Engine Type in your personal profile page.
Doing this will makes it much easier for other members to answer/comment on your posts/issues.
When dealing with support, remember, the "No" is always there, you are just looking for the "Yes".
twospirits is offline
post #19 of 23 (permalink) Old 03-29-2017, 01:59 AM
semco's Avatar
2016 Tucson Ultimate AWD
Quoted: 382 Post(s)
semco is an unknown quantity at this point
David, why you won't hide that wire under the dash and connect DVR directly to lighter?
If you have a lovely wife, sexy hot lover, cool car, no problems with the government and revenue authorities, and when you go out the sun always shines and all passers smile to you - common dude, say NO to drugs!
semco is offline
post #20 of 23 (permalink) Old 03-29-2017, 02:02 AM
semco's Avatar
Quoted: 382 Post(s)
Originally Posted by twospirits View Post
I like that idea.
TS out
paying extra $50!? Your cable from DVR already has the fuse, you can cut off a plug itself and do hidden connection tap wires to the fuse box easy.
semco is offline
