2016 1.6t spark plugs part - Hyundai Forums : Hyundai Forum
post #1 of 12 (permalink) Old 02-07-2017, 11:44 PM Thread Starter
Quoted: 3 Post(s)
staffpro1 is an unknown quantity at this point
Do you guys know part #for 1.6t spark plug? I can't find anywhere and what is recommended torque setting?
staffpro1 is offline
post #2 of 12 (permalink) Old 02-10-2017, 12:26 PM Thread Starter
Quoted: 3 Post(s)
-part number is 18849-08080 however I am confused the manual says to R every 36,000km but my service department says they (laser iridium) should last 100,000km.... who do i go by
post #3 of 12 (permalink) Old 02-10-2017, 01:27 PM
Drives 2016 Tucson Eco AWD
Quoted: 88 Post(s)
gggplaya is an unknown quantity at this point
That's 22,000 miles, no way you have to replace spark plugs every 22k miles.
gggplaya is offline
post #4 of 12 (permalink) Old 02-19-2017, 10:41 PM
Skiddy's Avatar
Drives Ruby Wine 2016 Tucson Limited 1.6T AWD 1977 Chevy Silverado C-10 1997 Yamaha Virago1100SJ
Quoted: 11 Post(s)
Skiddy is an unknown quantity at this point
My manual says to replace every 72,000Km or every 36 months, are you sure you read the manual correctly?
This interval is for Normal Maintenance Schedule, the severe schedule simply says to replace more frequently...
Move over coffee, this is a job for alcohol!
Skiddy is offline
post #5 of 12 (permalink) Old 02-20-2017, 09:43 AM
Quoted: 88 Post(s)
Does anyone know who makes the OEM plug for hyundai? NGK,Denso etc.....
gggplaya is offline
post #6 of 12 (permalink) Old 02-20-2017, 11:04 AM
Tucson Tony's Avatar
Drives 2016 Hyundai Tucson LTD, Ultimate AWD Rides 2013 Triumph Tiger Explorer
Quoted: 189 Post(s)
Tucson Tony is an unknown quantity at this point
Denso Iridium #3479
Tucson Tony is offline
post #7 of 12 (permalink) Old 02-24-2017, 10:39 AM
roussfam
I'm going by what I have in writing from Hyundai....36,000kms, never mind what the flunky on the service desk says.
That's what is stated in my manual. For what it's worth this is only for the 1.6T, the regular 1.6 in the Accent for example is a much longer period.
roussfam is offline
post #8 of 12 (permalink) Old 03-20-2017, 02:14 PM Thread Starter
Quoted: 3 Post(s)
for whatever its worth i ended up buying Denso 3479 from rock auto for 9$/pop (dealer wanted 25$/plug) and dealer also said 100k KM at least. The Canadian manual says every 36k km which is 22.5k miles... kinda rediculous anyways i am at 56k km/35k miles and decided why not since i already have the plugs, took about 45minutes start to finish. torqued to 18.5 as per denso spec of 15-20. Hyundai canada CSR when phoned was also useless REP was contradicting the manual and saying "although manual says R you should inspect it and change if necessary".
Here is a picture of what i took out OEM was NGK iridium, they look like they could probably keep going for a while but do have quite a bit of carbon deposit however i am no mechanic or spark plug expert i am going by the denso replacement pictures. So conclusion they can probably keep going but your performance is probably affected at least a little by these deposits. I think a safe medium then is double the canadian manual interval of 36kkm = 72-80kkm = about every 50k miles for optimal performance. Or if you don't care about performance 100k km is probably fine but the incomplete combustion would probably cause problems later on i'm guessing. I use top tier rated regular 87 gasoline here in canada.
*once again i'm not a mechanic i work in healthcare but i do alot of stuff diy with car so someone with more expertise please chime in.
post #9 of 12 (permalink) Old 03-20-2017, 02:16 PM Thread Starter
Quoted: 3 Post(s)
looking at NGK's replacement pictures it looks like they are probably fine though, more deposits than normal but marginally, anyways i have 4 extra's now in case anything ever happens.
post #10 of 12 (permalink) Old 03-20-2017, 07:12 PM
wallyjay's Avatar
Drives 2016 Tuscon Limited/Ultimate AWD 2007 SantaFe 3.3 FWD
Quoted: 97 Post(s)
wallyjay is an unknown quantity at this point
For what it is worth...I have the original iridium plugs in my SantaFe. They are approaching 155,000 miles. Eventually I guess I will replace them.
I plan on replacing the ones on my Tuscon at the specified interval. I am told that the 1.6 turbo is hard on plugs. My manual says to replace plugs at 45,000 miles.
wallyjay is offline
