Tucson 2017 Xenon replacement for High beam - Hyundai Forums : Hyundai Forum
 7Likes
post #1 of 37 (permalink) Old 11-21-2016, 01:42 PM Thread Starter
JonasT's Avatar
Drives Hyundai Tucson -2016
Quoted: 8 Post(s)
JonasT is an unknown quantity at this point
Lightbulb Tucson 2017 Xenon replacement for High beam
So, the new Tucson comes with LED Low beam and Halogen(!) low beam. At least the european spec. Not to be a grumpy old man (I really am ) but in the year of 2016 and soon 2017, not using at least Xenon feels a bit cheap to me.
I wanted to check with you guys if anyone have tried a HID conversion for the High beam? Make/model, Canbus issues, and so forth.
Or even better if anyone tried a LED conversion. To my knowledge though, the LED technology for easy retrofitting is still not there yet. Having said that though, I would love to be miserably put down as poorly informed and a non-believer!
Present and past drives: Hyundai Tucson 1.6 T-GDI DCT-7 4wd -16, Audi A6 Allr 3.0 TDI -15, Audi A6 Av 3.0 -13, Audi A4 Allr 1.8 TFSI -11, Audi A4 Av 1,8 TFSI -09, Audi/MTM 240 -00, BMW 325 -06, BMW 328 -96, BMW 325 -92, MB C180 -13
JonasT is offline
post #2 of 37 (permalink) Old 11-21-2016, 02:56 PM
EpicKLF's Avatar
Drives a Hyundai Tucson 2.4 and a Mk1 Audi TT
Quoted: 42 Post(s)
EpicKLF is an unknown quantity at this point
my experience is from the way the headlights were designed, its so tough putting "larger" sized LED's into the housing properly.
Tried installing LEDs with the CPU sized heatsinks and it cant even go through the dust cap. then i installed LEDs with the ribbon style heatsinks and stuffed them inside, but then i get intermittent warnings saying my high beams aren't working (even though they are) and from the way the LEDs were designed, they were not any higher than the stock LED low beams so essentially no difference.
i gave up and just bought upgraded "xenon blue" halogen bulbs for now. i am curious if anyone managed to stuff xenons with their huge ballasts inside tho
EpicKLF is offline
post #3 of 37 (permalink) Old 11-21-2016, 03:39 PM
2016 Tucson Limited (Ultimate)
Quoted: 160 Post(s)
srudenko is an unknown quantity at this point
Check out this thread. I replaced the stock high beams with Philips halogens that are 5000K. They are nearly as white as my 6000K HIDs
http://www.hyundai-forums.com/2016-tucson-ix35-models/457250-high-beam-h7-led-replacement-post4725002.html
srudenko is offline
post #4 of 37 (permalink) Old 11-22-2016, 03:44 PM
Quoted: 18 Post(s)
Shazzy is an unknown quantity at this point
I installed LED R3 9600lm (from Aliexpress, 40$/pair) on low and high beam (base model). For low beam you need adaptor, not needed for high beam, fit perfectly inside of housing, no canbus error.
Huge improvement over yellow stock halogen.
Shazzy is offline
post #5 of 37 (permalink) Old 11-23-2016, 05:17 AM Thread Starter
JonasT's Avatar
Quoted: 8 Post(s)
Big thanks! Did you try with resistors as well?
JonasT is offline
post #6 of 37 (permalink) Old 11-23-2016, 05:35 AM Thread Starter
JonasT's Avatar
Quoted: 8 Post(s)
Thanks! Looks good. Also, a very good description in this thread.
For me, HID is prefered over Halogen because of many things. For example the lifetime, can be put directly into a Halogen reflector, length light image. LED would be even better, imo but, as it seems, more difficult to find in of the shelf - straight into the socket kits..
Halogen with blue filter would not be my first choice..
JonasT is offline
post #7 of 37 (permalink) Old 11-23-2016, 05:40 AM Thread Starter
JonasT's Avatar
Quoted: 8 Post(s)
Interesting!
Did the LEDs come with built-in CANBUS resistors or do you use resistors outside of the light housing? (Or do you live with a constant warning? )
Can you share some pictures from the installation?
How was the range and width effected?
JonasT is offline
post #8 of 37 (permalink) Old 11-24-2016, 04:42 AM
jfrsurvey's Avatar
Tucson 1,6 T-GDI
Quoted: 11 Post(s)
jfrsurvey is an unknown quantity at this point
And can you tell us wich one it at AliExpress (Link?)...
What means the "R3"??
jfrsurvey is offline
post #9 of 37 (permalink) Old 11-24-2016, 11:28 PM
semco's Avatar
2016 Tucson Ultimate AWD
Quoted: 390 Post(s)
semco is an unknown quantity at this point
I did it, swapped halogen to HIDs. Plz give yourself a good thumb up and get morimoto, as you gonna get what you pay for! There is my thread how-to-do it as well.
1. you need can bus HIDs
2. you need load resistors.
everything for both lights and morimoto`s are the best over cheap chinese stuff, at least they won't blow up in a week after installation.
Polaraco likes this.
If you have a lovely wife, sexy hot lover, cool car, no problems with the government and revenue authorities, and when you go out the sun always shines and all passers smile to you - common dude, say NO to drugs!
semco is offline
post #10 of 37 (permalink) Old 11-24-2016, 11:47 PM Thread Starter
JonasT's Avatar
Quoted: 8 Post(s)
Thanks. Great thread!
...hyundai-forums.com/2016-tucson-ix35-models/421898-led-low-beam-fog-hi-beams.html
(I can't post links yet..).
I clearly need to search before posting..
JonasT is offline
