Ok. So I have been looking all through the internet, all though my owners manual, and I have even been into 3 different auto store franchises. But I cant find what size headlights my 2016 hyundai tucson eco uses. Does anyone know what size bulb I need to buy to replace my OEM bulbs? Thank you!
Hi Huntley, I came to this forum to find the same information. There is another forum thread that suggests that the Low Beam is an H11. As for the High Beam, I have not found this information yet. I think the thread title is something about Low Beam HID's or something.
the Halogen bulbs are H7 in low beam and also in high beam here in the middle east.
We have found out that different region hyundai has been using different Bulb sizes. to make sure just get the bulb out of the housing.
all markets have H7, there is no H11 on tucson.Second, don't waste your money and get LED bulbs, it won't work and you can't drive with these LED bulbs....
make sure to order the Philips Luxeon MZ chip for the high beam !
They are only 2500 "Chinese" lumens which is rather lower than a HID would output, but easier to install, you don`t have to cut anything and the heat output is marginal. I wanted to tape the whole inside with aluminum tape, which came out to be unnecessary. Also you don`t need to use a warning canceler resistor.
First impression is really great. Not as strong as a HID on my dads Ford Kuga but, it is a very pleasant light that does shine in a much wider spectrum, the objects lit by LED are more naturally colored and it does not strain your eyes like HIDs. And in a year or two there will be a replacement bulb with even higher output and higher energy efficiency.
Hello kris7i4n, do these LED H7 that you installed for high beam work for the low beam, as well? Semco and the other people replacing the stock bulbs say that LED won't work instead of halogen bulbs....
I am not sure about led in low beams, my TLe version came with double LED projector headlighs for the low beam. If the low beam is a h7 there should be no problem, if there is enough space to install. I don`t think I can answer your question, maybe someone else on the forum who actually swapped the bulbs will give you a more detailed answer.
ah, ok...I thought TLe in your region came with halogens in both low and high beams. Semco, who is by far better expert in this field than me, says LEDs don't work, but I still don't understand why. If it works in the high beams it should also work in the lows, as well.
Fitting in LEDs, seems like a much easier job than fitting HIDs, that's why I am insisting on LEDs
What Semco would have meant by saying that the LEDs wont work in low beam is that as its a projector lense and when you install a LED into it, the Light output is much much lesser than a HID.
Solman98 which LED's did you use in your Elantra and are you going to use the same ones in your Tucson? Also which ones did you use in the Elantra fog lights?
Check the link on post #20 . That's the style I used for each (fogs are 881's). And yes, that is what I'll put in the Tucson.
Originally I installed a different set in the fogs, they were only rated at 750 lumens and too blue for my taste. Once I installed the headlights and saw the color was whiter, I put a set in the fogs and I can actually tell when they are on now.
but i will try out this LED in my High beam. We here in middle east very rarely use the High beam and mostly only to flash the car in front to give way.
@navein the install is super easy. takes up 5 minutes of your time, if you don`t waste time with aluminum taping the inside of the cover, like I did... that was totally unnecessary, cause after 10 minutes of the high beams on you can hold the heath sink belt in your hands...
Aluminum taping the inside of the cap
Everything installed, you can see the small power controller on the left
The bulb inside the high beam refelctor
Low beams
Low beams + High beams
Before I could install these bulbs (Osram Rallye 65w Ultra High Output H7) I sold my 2016 ECO. Have used this type of bulb before. 50% increase in lumens. For more info pm me.
my LED bulbs received and installed, a great improvement compared to the stock halogen lamp; thanks to kris7i4n for sharing your installation. Here pics
I'm currently running hid in my 2016 tucson eco... I'm having lots of trouble blowing the bulbs or the decoders. Has anyone installed these on a U.S. eco and what adapters did you use for the low beams? I have the recommended adapters for the hid install but I'm fairly certain that they are not going to be compatible with the led headlights. This has got to be the worst design I've ever seen and they should have built them just like the high beams with the clips.
I'm currently running hid in my 2016 tucson eco... I'm having lots of trouble blowing the bulbs or the decoders. Has anyone installed these (led) on a U.S. eco and what adapters did you use for the low beams? I have the recommended adapters for the hid install but I'm fairly certain that they are not going to be compatible with the led headlights. This has got to be the worst design I've ever seen and they should have built them just like the high beams with the clips.
I have tried several led lights for low beams.
The first 2 sets of the led lights are whitout any message on my dashboard. This are 40W lights. (Cree LED XHP-50)
My last (and current) set LED lights are 55W (Cree LED XHP-70) and gives an error on my dash. I solved it by placing the following resistors Aliexpress.com.
my leds are 25W / bulb so i hope it will be without error message but i have also resistors in case of error
now i'm waiting for holder as it's not possible to mount it without holder to light.
LED bulbs don't work as well in projector housings because they don't put out a 360 degree light pattern. You should really use an HID or halogen bulb for a projector housing.
Welcome to the forum. From what global market is your Tucson and exactly what is the trim? There are ways to add that information in your profile so that it appears to the left of your posts. Doing so avoids these type of questions.
