Dangerous, Horrible DCT - Page 3 - Hyundai Forums : Hyundai Forum
 1437Likes
post #21 of 1951 (permalink) Old 02-10-2016, 09:21 AM Thread Starter
Quoted: 15 Post(s)
cardplayer is an unknown quantity at this point
Yes. When it did the no-power thing, it ignored my attempt to shift into manual mode. The display said "D", but it would not go. I even tried going to "P", which it obliged, then back to "D". It still would not switch to manual. There is another post where the details indicate that the transmission seemed to stay in an inappropriately high gear after a stop. That would make sense based on my years of driving vehicles with manual transmissions. If you try to pull out from a stop, in 3rd or 4th gear, you can do it, but it requires really high rpms, and a ton of fine clutch work/slippage.
I cannot recreate the no-power issue. The transmission temp warning may be easily recreated by performing about 6 or 8 sporty starts and dead stops. This is something you might do if going through a series of stop signs, for example. The vehicle will suggest that you "pull over safely". Excuse me?
Also, cold weather does seem to make this vehicle act up much more often. I thought they had cold winters in Korea. My backup camera and radio fail intermittently when the ambient temperature is below 20. Also, the clutch slippage behavior in low gears is more pronounced in those conditions.
cardplayer is offline
post #22 of 1951 (permalink) Old 02-10-2016, 10:08 AM
Sonata Limited 2014 with Tech Pkg - traded in for a Tucson Limited with Ultimate Package - Winter Wh
Quoted: 125 Post(s)
slhcrnp is an unknown quantity at this point
Sigh. We are forecast for bitter cold this weekend in my area. I will take the car out at some point and carefully monitor - and will have my cell at my side. Hope Hyundai gets on this.
slhcrnp is offline
post #23 of 1951 (permalink) Old 02-10-2016, 11:40 PM
Primacywolf's Avatar
2016 Sedona Sunset Tuscon
Quoted: 7 Post(s)
Primacywolf
This is the exact same issue I had and posted about in an earlier thread, "no power stuck in middle gear no manual mode". The dealer replaced the part FP NUMBER 41470-2D011 ACTUATOR ASSY-CLU
So far it seems to of corrected the issue. It took them 2 weeks to get the part in from Hyundai!
James21 likes this.
Primacywolf is offline
post #24 of 1951 (permalink) Old 02-11-2016, 10:02 AM Thread Starter
Quoted: 15 Post(s)
It happened again. This time, I captured a video! I will post it to YouTube. I may also create a community, so that we may all upload video proof of these problems. It is not always possible to drive to a dealer to get a code. In fact, in the case of the high temperature warning, there actually is no code. I found that out first-hand. This is because they consider the condition "normal"!
Anyway, I got a video of the failure to accelerate from a stop. Stay tuned.
post #25 of 1951 (permalink) Old 02-11-2016, 11:29 AM
Quoted: 1433 Post(s)
Ok,, similar situation with Veloster.. wouldnt accept attempt to calibrate clutch engagements,, had to replace an actuator,, no big deal.
rmissourimule and James21 like this.
sbr711 is offline
post #26 of 1951 (permalink) Old 02-11-2016, 11:37 AM Thread Starter
Quoted: 15 Post(s)
It's a big deal when it has been into the shop twice and they refuse to acknowledge the problem.
flames9, Old's Cool and ShellyD like this.
post #27 of 1951 (permalink) Old 02-11-2016, 11:47 AM
Tell them to do the clutch calibrate as a "courtesy"..... see if the calibrate operation allows them to proceed, or fail to complete.. then they should have something to go by..
While they have GDS plugged in, verify all ECU UPGRADES is current.........
James21 likes this.
sbr711 is offline
post #28 of 1951 (permalink) Old 02-11-2016, 01:54 PM
Accord 2004, silver, stick
Quoted: 264 Post(s)
MaybeHyundai is an unknown quantity at this point
WOW. Conclusion for me is NO to DCT. Screw ECO models.
You know, life was much easier when Yugo was on the road. So simple, no electronics, N.Koreans nukes would not stop it, and GPS was just plain paper map and beautiful wife...
mcc17ss and Old's Cool like this.
MaybeHyundai is offline
post #29 of 1951 (permalink) Old 02-11-2016, 02:04 PM Thread Starter
Quoted: 15 Post(s)
VIDEO PROOF:
https://www.youtube.com/watch?v=TCVtr_zcyrs
It happened again this morning as I was stopped at a toll booth. You will see the cruise control light, but it does this whether or not cruise was used previously. Sometimes, it does it as soon as I leave my driveway.
James21 and mad_sb like this.
post #30 of 1951 (permalink) Old 02-11-2016, 02:10 PM
FSRBIKER's Avatar
2016 Tuscon Eco AWD, Caribbean Blue; 1969 Ford Bronco-Rock Crawler
Quoted: 40 Post(s)
FSRBIKER is an unknown quantity at this point
ECO, Sport and limited all use the DCT trans.
Extreme 4x4 Parts Fabrication
FSRBIKER is offline
