Amica Reverse Light Switch - Hyundai Forums : Hyundai Forum
Old 11-30-2010, 06:38 PM   #1 (permalink)
davie200
Unhappy
New to this forum, and first post.
Any idea where I might get a workshop manual for my 2001 Amica si, just changed my reverse light switch (which was not working), new one installed, and light permanantly on, wondered if a ball bearing has fallen out when replacing, as switch works fine out of gearbox (lights on, then off when plunger pressed).any help would be appreciated.
Incidently just changed water temperature sensor easy job about 30 mins, located in thermostat housing, held in with 1 spring loaded clip.
davie200 is offline   Reply With Quote Quick reply to this message
Old 12-01-2010, 04:10 PM   #2 (permalink)
davie200
Exclamation
Fixed, Steel ball bearing had fallen out. Also obtained Basic workshop manual.YEE Haa.
Old 12-06-2010, 12:15 PM   #3 (permalink)
lovejoy's Avatar
ATOS squareback & ATOS roundback (Amica)
lovejoy
Hi Davie, where did you find the workshop manual ? and how much ?? cheers
lovejoy is offline   Reply With Quote Quick reply to this message
Old 12-12-2010, 05:14 PM   #4 (permalink)
davie200
Found the nanual online when I searched for Hyundai Santro 2002 shop.Sorry, cant find the link though, hope this helps.
