Rear Door Quarter Window - Hyundai Forums : Hyundai Forum
Old 06-22-2010, 05:25 PM   #1 (permalink)
btman1
Hi, the small fixed window on my rear door got smashed. I have a replacement but need some idea on how to fit it. Any pointers would be appreciated.
btman1 is offline   Reply With Quote Quick reply to this message
Old 06-22-2010, 06:03 PM   #2 (permalink)
ADMINISTRATOR
Montego's Avatar
welcome to the forums
you will need to remove the door trim and then remove the main window by removing the rear window runner, once the runner is removed from the door you will be able to remove the quarter light glass with its rubber moulding, this can be a tricky job if you have never done it before and if you are not confident it may well be better to get it done at your local repair shop
MONTEGO
Old 06-26-2010, 08:00 PM   #3 (permalink)
btman1
Thanks the trim is a bit of a problem with removing the winder handle, seen the topic about the clip but can't get into to remove it, so will probably have to get it fitted will give it another go. Thanks again.
