LinkBack | Thread Tools |
#1 (permalink) |
Drives Veracruz Limited
I have an 07 Limited and lately the AWD isnt working properly, it tries to engage, the esc goes on, and then the AWD drive light comes on, and after a while it goes off, but will come back on when it tries to kick in the rear wheels into drive,
What could the issue be? Before i head to my app to get it checked out, next monday |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
as i understand....the awd system is only good up to speeds 25 mph and below. above that, it is not engaged.
you didn't specifically mention the scenario when this happens...but...that could be one of the culprits. |
#4 (permalink) |
you have a lock button on the dash...i'm assuming it is engaged.
for some reason, i'm betting this isn't like a rav4 or crv system...and definately not a subaru set-up, meaning, i don't think the awd will kick in automatically like the others do when it detects wheel slippage. i'm guessing that it has to be locked in for it to work. if you have it locked in and it still wont' engage...and if you still have a warranty...it should be well worth a visit to the dealership to diagnose and get repaired. |
#5 (permalink) |
2011 Sonata 2.4L Limited
2012 Veracruz GL FWD
In normal mode (AWD Lock not selected), the system functions like a FWD vehicle. If it detects a loss of traction, the system will automatically apply power to the rear (AWD mode) to regain traction, it will then return to FWD mode when traction is regained. The AWD LOCK function (when engaged) will apply power to all wheels for increased traction (similar to a transfer case/differential lock) but will automatically dis-engage above approx 20KPH to prevent damage to the system.
#7 (permalink) |
If it's the AWD light on the instrument cluster, then it's indicating a problem with the system. There should be a code set in the ECU but they are usually not accessible with a generic OBD scan tool. It could be as simple as a low fluid level in the transfer-case or impending sensor failure.
#8 (permalink) |
So i took it in today, after 2 hours they came to me saying they couldnt find the problem and waiting on Hyundai tech to help, 2 hours after they came back and said the Coupler needed to be replaced at a cost of 2030.00.
It also gave them codes B0E00 U3A00. Im a little skeptical, not sure as sometimes it works and sometimes it doesnt Any other advice |
#9 (permalink) | |
You can sign up to HMASERVICE, it free and you'll have access to a lot of information. Last edited by sienna1; 01-22-2013 at 06:49 AM. |
#10 (permalink) | |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
