veracruz radio - Hyundai Forums : Hyundai Forum
Old 10-25-2012, 06:27 PM   #1 (permalink)
jh89296
Send a message via AIM to jh89296
Default veracruz radio
have a 2020 hyundai veracruz and the radio does not show any numbers on display.radio works light on display works but nothing shows up to id the station or disk.need help on this matter thanks jim
jh89296 is offline   Reply With Quote
Old 10-25-2012, 10:21 PM   #2 (permalink)
2008 Hyundai Veracruz SE 2006 Honda Accord EX-L
krnjun is an unknown quantity at this point
Sorry, our VCs are 2007-2012.. You're well in to the future huh
krnjun is offline   Reply With Quote
Old 10-26-2012, 08:43 PM   #3 (permalink)
jh89296
Default radio 2010 veracruz
sorry about the year its a 2010 veracruz. the radio works but the display is just blue will not show any information.help please.
Old 10-26-2012, 08:54 PM   #4 (permalink)
sienna1's Avatar
2011 Sonata 2.4L Limited 2012 Veracruz GL FWD
You can try resetting the head-unit by pulling all fuses related to the radio or removing the negative cable from the battery for a few minutes. For the year of the vehicle, it should still be under warranty unless you're over the mileage limit.
sienna1 is offline   Reply With Quote
Old 11-12-2012, 09:09 PM   #5 (permalink)
jh89296
trird to reset .took the radio out unpluged all cordx reinstalled.no go radio works but no display just blue.light.
Old 11-12-2012, 09:11 PM   #6 (permalink)
jh89296
tryed to reset it took it out unpluged all cables reinstalled no go .radio works but still just blue screen.no numbers or anything on display just blue light.its out of warrenty thanks jh
Old 11-13-2012, 09:22 AM   #7 (permalink)
fear24 is an unknown quantity at this point
if you have done all that....i'd be willing to bet your head unit is no good. why...i have no idea. now, you will need to decide whether if you want factory replacement or aftermarket installed.
WeatherTech Liners
SR Deluxe Strut Bar
Tint - Llumar (35/15/80)
LED Cupholder Illumination
fear24 is offline   Reply With Quote
Old 11-13-2012, 11:36 AM   #8 (permalink)
sienna1's Avatar
Could be a failed display or loose connection with-in the radio. You could try checking the internal connections, just remove the radio from the face-plate (makes handling and access easier) then try removing the top cover or radio face to check for loose connections. Good-luck
Old 11-13-2012, 12:16 PM   #9 (permalink)
jh89296
Default radio
thanks for all of the replays. im thinking about putting in a 6 disc touch screen-radio with blue tooth gps and dvd have already bought the faceplate..anyone have any help on this?thanks jim
Old 11-13-2012, 01:30 PM   #10 (permalink)
sienna1's Avatar
See: replacing radio, need dash kit.
