Crankshaft Position Sensor Replacement - Hyundai Forums : Hyundai Forum
Old 04-11-2009, 08:39 PM   #1 (permalink)
mterry127
Hey everyone, I have a 2001 santa fe 2.4. I have a p0335 code and I'm looking to replace my crankshaft position sensor/ angle sensor....I know I have to take the timing cover off but I want to know is it easy enough to do on the street? I plan to do it monday when the dealer opens because I can't find the part anywhere except there. I need to be in work by 3 that day. Could anyone give me a step by step process on how to do it? That's for your time.
mterry127 is offline   Reply With Quote Quick reply to this message
Old 04-12-2009, 03:23 PM   #2 (permalink)
Hyundaiownersclub
QUOTE (mterry127 @ Apr 12 2009, 12:39 AM)
I suggest you have it done professionally as it involves removing cambelts and PAS pump. Depending on mileage cambelts and tensioners will also be required.
HYUNDAI TECHNICIAN BASED IN ESSEX UK. ALL HYUNDAI REPAIRS/MODS UNDERTAKEN INCL ENGINE/GEARBOXES Hi Scan and GDS equipment... www.hyundaiownersclub.co.uk / www.essex-tech.co.uk
Hyundaiownersclub is offline   Reply With Quote Quick reply to this message
Old 04-12-2009, 10:06 PM   #3 (permalink)
mterry127
Well the t-belts were replaced not to long ago...i wanna say maybe three years ago. I don't think getting at the crankshaft sensor requires moving the belts. I bought the haynes manual and It just say to remove the alternator and then the timing case comes right off. then it says the sensor is right next to a pulley and its accessable without removing the timing belt
Old 07-10-2009, 10:59 AM   #4 (permalink)
machav63
QUOTE (mterry127 @ Apr 12 2009, 07:06 PM)
Just curious, were you able to do this repair yourself?
How bad was it?
I may need to make the same repair.
Thanks,
Mike
machav63 is offline   Reply With Quote Quick reply to this message
