Changing Sparkplugs In A Hyundai Santa Fe 2005 3.5 - Hyundai Forums : Hyundai Forum
Old 07-06-2008, 05:54 PM   #1 (permalink)
Dan Johnson
Hi,
I'm new to the Forum and I'd like to say hello to all of you out there. I have a Hyundai Santa Fe 2005 3.5 and I'd like to change my rear spark plugs . From what I understand I have to remove the Plenum? What else is involved to get to the Spark plugs?
thanks,
Dan Johnson
imageman@optonline.net
Dan Johnson is offline   Reply With Quote Quick reply to this message
Old 07-08-2008, 05:07 PM   #2 (permalink)
byronguidry3732's Avatar
Dan,
Welcome to the world of compact engine design! Yes, you must remove the upper intake plenum to get the rear bank of spark plugs off. Unfortunately, this is becoming common with Japanese and Korean engines. You can reuse the metal gasket between upper and lower intake plenum. Use care when torquing the bolts from upper to lower, as the threads are aluminum and strip easily. Also, the three 10mm bolts that hold the upper plenum to the support bracket are very difficult to get re-installed as you have to work blind...you cannot get your head back there to see. Also, only loosen the upper locking nut on the cruise control and accelerator linkage but leave the lower locking nut untouched so you don't have to adjust the slack during reinstallation.
And I really hated the 2.3 liter engine in the Ford Ranger pickup made by Mazda but you did not have to remove the intake for that engine, only the skin on your knuckles.
Byron
Where's my bailout?
Old 07-15-2008, 04:40 PM   #3 (permalink)
Fla_Sunlover
Hi Dan, my questions is why? The engine is designed to go without changing the spark plugs for a very long time.
What exactly were you two doin in the woodshed??!!
Fla_Sunlover is offline   Reply With Quote Quick reply to this message
