Hard To Start After Fill Up. - Hyundai Forums : Hyundai Forum
Old 04-01-2008, 02:42 PM   #1 (permalink)
ututkaa
every time i stop for gas..my 01 santa fe is hard to start..it would take 4 to 5 start before she goes, then i have to keep the rpm up, bring her to idle..after that shes ok, till the next fill up.. the only way around this is to keep her running while gassing up..while filling up she run rough idle, some time engine shuts off..then its hard to start..any idea's?
thankz eh!
ututkaa is offline   Reply With Quote
Old 04-02-2008, 06:22 AM   #2 (permalink)
motorider
hi there ututkaa did you get your filling problem fixed what was wrong with your motor????????????
motorider is offline   Reply With Quote
Old 04-02-2008, 06:51 AM   #3 (permalink)
MODERATOR
trajetXG's Avatar
Drives: A 2008-7 Seaters Santa Fe CM
trajetXG is an unknown quantity at this point
Have you change your fuel filter?
Hyundai...Drive your way.
trajetXG is offline   Reply With Quote
Old 04-05-2008, 04:18 AM   #4 (permalink)
lovemysantafe's Avatar
Drives: 2012 Elantra Limited
I had this problem intermittently until about a year ago when it stopped without warning. It seems to be isolated to the 2.7 liter motor as I have read of another member having the same problem. It was the purge control valve being faulty. I'd give it to your dealer, depending on how frequently it occurs. Best of luck to you...
- Andrew
Titanium Gray / Gray Leather
KDM headlights w/NightBreaker high beam bulbs, 30% tint all around, front plate delete with BumperPlugs, 37W fog lamp bulbs, Honda Fit wipers
KYB rear shocks, 5K white license plate and trunk LEDs
, V3 Triton rear turn signal LEDs, custom leather steering wheel wrap w/contrasted stitching, KDM aluminum pedal set.
lovemysantafe is offline   Reply With Quote
Old 10-22-2011, 11:01 PM   #5 (permalink)
tim_manock
Default I may have the same issue?
I think I may be having the same issue. A while back, the CEL lit up with a P0441 code. Checking online, the purge control solenoid valve is usually to blame. Brought it to the dealer and they "fixed" it. Then, my wife was driving the Santa Fe and filled up the tank...and it stalled soon after turning the engine on. Based on the indicators that lit up, she (as well as a few others at the gas station) assumed that the battery was to blame. She found someone that jumped her and she was on her way. We eventually replaced the battery and thought that all was well...until the next time we had to gas up the vehicle. Again, we took it to the dealer to fix. It got "fixed" and we continue to have the starting problem just after filling up (pump stomps automatically...not topping off). I took a video from my cell of what the dashboard looks like when I try to start the vehicle after filling up and uploaded it here: Hyundai Santa Fe problem after fill up - YouTube
Note that I didn't touch the gas pedal, even though it looks like I was revving the engine. Suggestions?? We now have the P0441 code again. I have found that if I wait about 20 minutes after filling up before I attempt to start the vehicle, it doesn't stall. It does come close though. Unfortunately, I don't always have the luxury of waiting 20 minutes after I pump gas without someone getting angry that I haven't moved my vehicle.
tim_manock is offline   Reply With Quote
Old 10-23-2011, 03:32 AM   #6 (permalink)
Truvy
Exclamation Replacing Purge Valve...
I wrote a step by step post regarding the replacement of the Purge Valve under the Forum Topic:
03 2.7L does not start after filling fuel
If you have any questing post them and I will clarify any misunderstandings.
Patrick
Truvy is offline   Reply With Quote
