Tires - Hyundai Forums : Hyundai Forum
Old 08-18-2007, 10:35 AM   #1 (permalink)
trent larson
Would like feedback on best tires for my two wheel drive santa fe?
trent larson is offline   Reply With Quote Quick reply to this message
Old 08-18-2007, 11:04 AM   #2 (permalink)
ADMINISTRATOR
Montego's Avatar
welcome to the forums
have moved your question to the 'santa fe' forum this forum is for new member introductions only
MONTEGO
Old 08-18-2007, 11:06 AM   #3 (permalink)
joekewl's Avatar
joekewl
to the forum
joekewl is offline   Reply With Quote Quick reply to this message
Old 08-19-2007, 03:05 PM   #4 (permalink)
TeamCNY
What type of driving do you do (conditions, etc.).
What are your criteria when you say "best"?
Best mileage? Best dry handling? Wet handling? Quiet? Long lasting? Cold weather performance?
I shopped around a lot for tires when my first set were worn. I settled on replacing them with the same things that came from the factory.
Engineers tweak cars to work well with the factory-spec tires. Other tires will work well, and may be better based on your definition of "better", but I was happy with the factory-spec ones for the first 45,000 miles, why not stick with them?
TeamCNY is offline   Reply With Quote Quick reply to this message
Old 08-19-2007, 06:53 PM   #5 (permalink)
fmfm's Avatar
fmfm is an unknown quantity at this point
as TeamCNY said
each brand had its own characteristics
where bridgstone for examble is good for handling but noisy and wear fast (due to their grip)
and so on
so you must identify what you want
for me id like a quit and comfortable tires.
fmfm is offline   Reply With Quote Quick reply to this message
Old 09-22-2007, 07:23 PM   #6 (permalink)
bnelsonr's Avatar
bnelsonr
I have an 05 sany 2WD. It came with the Bridgestone H/T. I found an independent testing of tires. I can't remember which one. Anyway the H/T was third from bottom of list. The H/L series was second from top. I went to the dealer and exchanged the H/t for the H/L series. I had 400 miles on them (1 week old). He exchanged the under warranty after he asked me if they road hard. The H/L do ride better. Most car manufacturer's mostly put on a tire that just makes the grade unless you are buying an expensive vehicle.
2011 Elantra Limited
09 Santa Fe Limited
05 Santa Fe GLS
03 Sonata GLS
bnelsonr is offline   Reply With Quote Quick reply to this message
Old 10-30-2007, 03:25 PM   #7 (permalink)
Fla_Sunlover
I have Firestone Destination's on my '01 Santi AWD. Low noise, great ride, great wear & traction. I would buy them again.
What exactly were you two doin in the woodshed??!!
Fla_Sunlover is offline   Reply With Quote Quick reply to this message
Old 11-22-2007, 03:41 PM   #8 (permalink)
2002sf2wd
I put Firestone Destinations on the front of my 02 2wd at about 64K. I haven't rotated tires for 20 years--only have to buy 2 tires at a time that way. Just watch the alignment & fix if any uneven wear shows. Still have the original Goodrich Long Trail TAs on the rear at 95K--I think they'll run at least another 10-15K! The Goodrich tires have worn like iron but have lousy traction. The Firestones have great traction and seem to be wearing well. I live in Iowa & drive in snow a lot, so traction is important. I haven't had to align the SF yet. It's been one of the best vehicles I've ever owned. I'll be buying two more Firestones if I still have the SF when the TAs finally wear out.
2002sf2wd is offline   Reply With Quote Quick reply to this message
Old 11-25-2007, 01:21 AM   #9 (permalink)
Bizzenn
I had an 03 tibby that came with Michlin
Pilot sports. Thats what goes on porsches. Their like a grand a set. i will say though that the Bridgestones on my 06
Santa fe are B(Temp) B(Traction) but I ve had no issues.
Bizzenn is offline   Reply With Quote Quick reply to this message
