2001 help with dashboard lights - Hyundai Forums : Hyundai Forum
Old 11-25-2013, 07:22 PM   #1 (permalink)
Santa Fe
kroll124 is an unknown quantity at this point
Default 2001 help with dashboard lights
it started with me trying to rewire stereo wires for a new stereo, accidentally let 2 wires touch eachother. Found out that all the dash lights(including all the centre console lights) were as dim as they can possibly be and after a while the stopped working completly.
couldnt find a fuse for dashlights on fuse diagaram so checked all the fuses one by one and non of them were burnt.
So does anyone know how could i solve this?
And how can some stereo wires cause this?
i think i has something to do with the "illumination wire"
kroll124 is offline   Reply With Quote Quick reply to this message
Old 11-25-2013, 09:31 PM   #2 (permalink)
Drives 2004 Hyundai Santa Fe 2.7L V6 FWD
Tadio is an unknown quantity at this point
Does this include the lights on your instrument cluster? If so wow that sucks. I too installed a new deck about three weeks ago and after doing so I realized my driver side speakers don't work. Not sure if it was like this, or if I caused this and only noticed after testing it all out post-installation.
Hopefully someone with the solution to your issue can help me figure out how to fix my driver side speakers.
Don't mean to thread hijack, figure this is related and don't want to make a separate thread just for this.
Tadio is offline   Reply With Quote Quick reply to this message
Old 11-26-2013, 04:23 AM   #3 (permalink)
Santa Fe
yup, the only lights on instrument cluster that work are lights that you somehow
cause to turn on ( like turning signal, highbeam light, gas warning light,)
i have had this problem for couple of months now and im getting real desperate.
Old 11-26-2013, 05:29 AM   #4 (permalink)
Drives Santa Fe GLS
SXIPro is an unknown quantity at this point
Maybe you shorted out the 'dimmer' switch(or dimmer module)? Have you tried messing with that?
SXIPro is offline   Reply With Quote Quick reply to this message
Old 11-26-2013, 06:38 AM   #5 (permalink)
Drives a Santa Fe 2.0L diesel, 4WD, year 2004
paul03 is an unknown quantity at this point
Almost certainly you shorted the instrument lighting wire to some ground.
The electronic dimmer (on left side steering wheel) could be damaged, so no output anymore. You could look into the servicesite https://www.hyundaitechinfo.com if you can find a schematic of the wiring to it.
Maybe there is a (blown) fuse inside, I don't know.
Also you could temporarily bridge the output lights wire to the incoming voltage on the connector, so you have instrument lights again.
Good luck,
Paul
paul03 is offline   Reply With Quote Quick reply to this message
Old 11-26-2013, 05:41 PM   #6 (permalink)
Santa Fe
yeah actually, i checked with a device ( dont know whats it called) which two of three wires complete the circuit and after bridging them nothing happened.
checked with the device again and there wasnt a powercircuit happening.
Gonna buy a new dimmer controlunit and see how it goes.
