santa fe front end noise-clunk! help!! - Hyundai Forums : Hyundai Forum
Old 09-06-2013, 10:48 PM   #1 (permalink)
hyundai santa fe 2006 V6
mooch1 is an unknown quantity at this point
Default santa fe front end noise-clunk! help!!
hi, i have a 2006 santa fe FWD 2.7L..love this truck..but recently i have a front end noise....a clunk noise at low speeds on small bumps,,.so i replaced the front left anf right end links,,(moog)
the noise is still there,,replaced both front left and right a-arms ,,the a arms are new and have new bushings and ball joints etc...noise is still there...WTF!...the vehucule has 73000km..struts?? any help is appreaciated,,thankyou.
mooch1 is offline   Reply With Quote Quick reply to this message
Old 09-06-2013, 11:46 PM   #2 (permalink)
lifeblows10's Avatar
Drives '11 Elantra GLS, formerly 02' Santa Fe LX
lifeblows10 is an unknown quantity at this point
Double check your bolts on the entire front suspension. My clunk happened to come from a loose bolt on my control arm. Do that before you dump any more money.
lifeblows10 is online now   Reply With Quote Quick reply to this message
Old 09-06-2013, 11:53 PM   #3 (permalink)
i will try that ,,thanks.
Old 09-08-2013, 10:58 PM   #4 (permalink)
Drives a 2006 Santa Fe 2.7
Hyundai_81
I have a sorda the same problem except mine does it when accelerating and braking. single clunk same vehicle as mooch1.. mine has 194,000 kms on it
Hyundai_81 is offline   Reply With Quote Quick reply to this message
Old 10-04-2013, 10:00 PM   #5 (permalink)
pemdas1972's Avatar
Drives 2002 Santa Fe LX 2.7 4wd 173,000 miles
pemdas1972 is an unknown quantity at this point
Check the inner tie rods. Jack the front of vehicle up and grasp tire at 3 and 9 o'clock positions and wiggle side to side. If the inner tie rods are worn you will hear a ticking sound. If that is the case it's best to replace both sides.
pemdas1972 is offline   Reply With Quote Quick reply to this message
Old 10-05-2013, 04:18 AM   #6 (permalink)
Drives a Santa Fe 2.0L diesel, 4WD, year 2004
paul03 is an unknown quantity at this point
You could look for loosened motor mounts. That could give a clonking noise at various speeds and conditions.
Good luck,
Paul
paul03 is offline   Reply With Quote Quick reply to this message
