problem starting 04 santa fe - Hyundai Forums : Hyundai Forum
Old 02-13-2013, 04:45 PM   #1 (permalink)
2004 santa fe 2011 sonata
willaber is an unknown quantity at this point
Default problem starting 04 santa fe
love my santa fe has been great but recently after putting fuel in
it does not seem to want to start.turns over and runs for a couple seconds then dies out.
have to keep accelerator pushed down for it to keep running. after that it seems to run and crank ok
any idea why it keeps dying out after fueling?
willaber is offline   Reply With Quote Quick reply to this message
Old 02-14-2013, 09:15 AM   #2 (permalink)
2003 2.7 Santa Fe 2001 3.0 Z3
More than likely a purge control valve. It's a know problem on this vehicle and you see all kinds of posts on it. If you look at step ten on this spark plug removal you can see it's location(they call it a vacuum valve).
Hyundai Santa Fe Spark Plug replacement on a V6 Cyl
Old 02-14-2013, 10:22 AM   #3 (permalink)
2006 Santa Fe 2.7 135,000 miles
o6santee
Do you get a check engine light?
I have an 06 Santa Fe, every couple of years I get a check engine light and the code tell me the purge valve. Turns out it is the gas cap itself, the rubber seal on the cap. I just buy a new cap and the light goes away.
If you don't get a light or code, then it's hard to say. Maybe the throttle position sensor?
o6santee is offline   Reply With Quote Quick reply to this message
Old 02-15-2013, 02:15 PM   #4 (permalink)
pattyd's Avatar
Drives '02 Santa Fe GLS 2.7L 4WD "Haylee"
pattyd is an unknown quantity at this point
If theres a mil, I'd put money on it being the gas cap. When you open the cap, do you hear pressure escaping? That can sometimes indicate a fault in the fuel tank evaporative emission system (but also indicates the cap itself is good, as its holding in the pressure). If you get gas somewhere else for a few fill-ups, and it stops, it might've just been poor quality fuel.
pattyd is offline   Reply With Quote Quick reply to this message
Old 02-15-2013, 02:38 PM   #5 (permalink)
'12 Elantra Sedan '12 Chevy Malibu '11 Kawasaki Vulcan 900 And yes, I drive them all.
Easy Rider is an unknown quantity at this point
Any chance that you are over-filling the tank ?
On many vehicles, that can get raw gas into the evap. emissions plumbing and cause problems.
Easy Rider is offline   Reply With Quote Quick reply to this message
