New ignition key stuck - Hyundai Forums : Hyundai Forum
Old 01-25-2013, 10:58 PM   #1 (permalink)
Santa Fe
Angeltooth is an unknown quantity at this point
Unhappy New ignition key stuck
Hi help please !!
I have a 2002 petrol, manual, 2.4 Santa Fe
It only had one key when I got it so I ordered a replacement key online -uncoded and uncut. When it arrived I got it cut - looked good. Before getting it coded I thought I would just test the cutting. Opened doors ok so tried it in ignition - fitted and turned engine over - did not start as not coded I presume.
However, when I tried to get the key out again it would not come out.
Could this be to do with it's transponder not being coded? Anyone know anyway I can get it out??
Any help gratefully received !
Angeltooth is offline   Reply With Quote
Old 01-29-2013, 06:46 PM   #2 (permalink)
peter9505's Avatar
Drives 2005 Santa Fe
peter9505 is an unknown quantity at this point
I would try putting a little oil and then wiggling it out , are you able to turn the tumbler still , maybe it's the tumbler spring that has broken and it can't turn back far enough to release the key?
peter9505 is offline   Reply With Quote
Old 01-30-2013, 09:39 AM   #3 (permalink)
2003 2.7 Santa Fe 2001 3.0 Z3
Originally Posted by Angeltooth View Post
Hi help please !!
Since it's a new key, I'd pull on the steering wheel to both sides while trying to remove the key.
johnaauld is offline   Reply With Quote
