Code P0401 - Hyundai Forums : Hyundai Forum
Old 08-23-2011, 12:05 PM   #1 (permalink)
Kestral
On my 2001 2.4 Santa Fe, I have been seeing this code for a few weeks now, Insufficient EGR Flow. I have cleaned my EGR valve, reset the code, and 100 miles later, the code came back. I then took the EGR valve out to inspect it, and it looked plenty clean. I have a replacement EGR valve and gasket coming in tomorrow, hopefully it will fix the problem. But assuming it doesn't, what else could it be? Pep Boys also told me I may need to replace the EGR purge solenoid and the EGR canister. I hear it could also be that the DPFE (differential pressure feedback EGR) sensor is faulty and needs to be replaced. These parts (solenoid, canister and DPFE) I have been unable to locate or identify, in the car or online. I will certainly follow up after I replace the EGR valve.
Kestral is offline   Reply With Quote Quick reply to this message
Old 08-23-2011, 01:02 PM   #2 (permalink)
QUOTE (Kestral @ Aug 23 2011, 12:05 PM)
Silly 2.4 & 3.5 with their EGR systems... 0401, easy code to deal with, just need to learn how system operates..
[b]Yep.. wrong repair attempt
[b]Yep
[b]Nope, but you already went and spent $$ for the special order parts, cost you to return them if they'll take them back..
[b]That's TOO easy... What controls EGR valve action ??
PCM uses various bits of engine sensor info to determine if we want to use EGR.. so we will duty cycle the EGR SOLENOID to apply vacuum to EGR diaphram to open valve and inject recycled xhaust gas into intake/combustion chamber to cool the mix. We have a vacuum regulator that takes manifold vacuum down to 7 in, and it need to work proper at regulating vacuum for EGR operation.. The regulator has to freely support the 7 inch of vacuum,, not slowly draw it when you test the part.. the solenoid is simple electric/vacuum test of valve inside.
We have more or less got to point that we just sell the regulator and soleniod and be done with it, then drive with vacuum gauge tapped into tube at EGR valve and watch for vacuum apply on top of valve.
[b]EGR purge ?? Dont think so.. EGR canister ?? Me thinks Beavis and company need to attend some proper engine controls/drivabilty/advanced emissions training courses
[b]FORD--> YES,,, Hyundai -----> NO
[b]Did I mention the EGR valve WILL NOT remedy the problem ??
Hyundai has a TSB in regard to EGR daignosis.. kinda drawn out in writing, but after you know what to look for as far as soleniod and regulator, you gots it remedied..
Old 08-23-2011, 09:16 PM   #3 (permalink)
Drives 95 Geo Tracker Drives 02 Santa Fe
revmup
Here is a sample of DIAGNOSIS. Pep Boys are not mechanics, they sell parts. Do not rely on the diagnosis of frankly idiots. If you can't get the info with your own scan tool, and manual, just go to the dealer, pay them to diagnose it, and buy the parts from them. How much were you willing to spend to go in a totally wrong direction? Sorry if I offended you, but when will we learn?
revmup is offline   Reply With Quote Quick reply to this message
