A Few 2002 Santa Fe Questions - Hyundai Forums : Hyundai Forum
Old 07-14-2011, 04:09 PM   #1 (permalink)
chuckinnc
Bought my wife a 2007 Sonata so no I need to ask a few questions so I can make use of the old Santa Fe, 1st how do you get the back seats to go all the way down, 2nd does anyone know the amp or wattage rating for the ACC 12v plug sockets?, 3rd has anyone ever had to get axcess to the
defrost/radio antenna wiring, if how to you get to it?
Sorry for all the questions but if anyone has a answer to any or alll then please reply.
2002 Santa Fe
2007 Sonata
chuckinnc is offline   Reply With Quote Quick reply to this message
Old 07-16-2011, 10:55 AM   #2 (permalink)
jadey1369
i am not sure about your voltage but your back seats do not fold all the way down, and to get behind the radio i believe there is a couple screws behind the ashtray door and you can pop off that center piece. the rest from there is all pretty visible.
jadey1369 is offline   Reply With Quote Quick reply to this message
Old 07-17-2011, 03:52 AM   #3 (permalink)
lovemysantafe's Avatar
Drives: 2012 Elantra Limited
To fold the rear seats:
- Remove the headrests and store
- Locate pull strap on bottom cushion and pull to flip bottom cushion forward.
- Unlock back rest and fold down.
As jadey said, they do not fold completely flat but it's close enough for government work.
To access behind the radio panel:
- Remove ashtray and locate two screws directly behind it.
- Remove both screws and give the base of the climate control panel a good yank. Don't be surprised if it hesitates...they can be finicky.
- With the climate control panel pulled forward, feel along the bottom edges of the radio panel and you'll locate two more screws that are oriented vertically. Remove those, as well.
- With the screws out, pop the bottom out gently and then give the top of the radio/vent fascia a push down at the back of the top in the center while tugging forward.
- Do [b]NOT pull too hard as the secondary switches are on a fairly short lead.
- Once the fascia is free, locate the secondary switches and simply disconnect them to get the entire piece free.
Installation is, as they say, the reverse of removal.
- Andrew
Titanium Gray / Gray Leather
