Transfer Case Fluid Change - Hyundai Forums : Hyundai Forum
Old 05-28-2011, 05:27 PM   #1 (permalink)
gschwaller
I am going to change the oil in the transfer case of my 2002 Santa Fe. I crawled under to scout it out and could not find the fill plug. Can anyone tell me what and where to look for to find that.
gschwaller is offline   Reply With Quote Quick reply to this message
Old 05-28-2011, 06:16 PM   #2 (permalink)
pemdas1972's Avatar
Drives 2002 Santa Fe LX 2.7 4wd 173,000 miles
pemdas1972 is an unknown quantity at this point
If you look carefully there is an allen bolt up towards the top of the transfer case on a 45 degree angle. I believe it is 10mm. I suggest you attempt to losen that one before you drain it just in case the bolt won't come loose (may want to spray some penetrating oil). Also filling it is a bit of a pain. If you buy 2 squeeze bottles of gear oil and cut the tip you can force it in the fill hole and squeeze a little more than half out of each bottle. Fill until fluid starts backing out of the lower part of the fill hole. Since you are doing that use the same oil to do the rear differential. Fill til fluid starts coming out of the lower part of the fill hole. Filling accurately is based on the vehicle being level so take that into account if you have the vehicle on ramps.
pemdas1972 is offline   Reply With Quote Quick reply to this message
