Fuel Injectors Not Working On 2002 Santa Fe 2.7 - Hyundai Forums : Hyundai Forum
Old 05-14-2011, 02:39 PM   #1 (permalink)
Nanuk
Send a message via MSN to Nanuk
Hi all,
I have good pressure to the fuel rail but no fuel injected into the engine. I am able to measure the resistance of the injectors and they are all good. I do not have a noid light to check the signal to the injectors. I checked spark and it is good. I primed the engine and it will start until fuel is gone.
Any help or suggestions will be welcome.
Nanuk is offline   Reply With Quote
Old 05-14-2011, 07:57 PM   #2 (permalink)
Nanuk
Update:
The 20A ECU fuse is blowing as soon as the vehicle turns over. Is there any place I can get an electrical schematic for the ECU circuit or at least for the 20A fuse.
Also this is a 2003 Santa Fe.
Old 05-15-2011, 11:26 AM   #3 (permalink)
QUOTE (Nanuk @ May 14 2011, 07:57 PM)
Update:
No need to start new topic --> http://www.hyundai-forums.com/t63911-santa...pt-to-start.htm
Answer in the link.
sbr711 is offline   Reply With Quote
Old 05-21-2011, 10:23 AM   #4 (permalink)
Nanuk
Problem solved. The ECU fuse was blowing because of a failed O2 sensor. I disconnect the sensor and the engine started.
