2004 2.4l Code P0401 Help - Hyundai Forums : Hyundai Forum
Old 02-17-2011, 05:32 PM   #1 (permalink)
HeliumGGA
EGR insufficient flow. EGR valve was pretty bad looking seemed a bit sticky when opened so I replaced it along with gasket. reset the computer but check engine light came back on code p0401 again. I know you can test by pinching the yellow striped hose at the throttle body to see if the solenoid is bad. The engine will stumble a bit when you pinch it closed, or so I am told. However when I pinch the hose, nothing happens. I do notice that the car does idle kind of roughly. Anyone have any insight into this issue? Thanks in advance.
HeliumGGA is offline   Reply With Quote Quick reply to this message
Old 08-02-2012, 07:52 PM   #2 (permalink)
2003 Hyundai Santa Fe 2.4l 4cyl 2wd 140k+ miles.
Danc83 is an unknown quantity at this point
Hi, I am having the exact same problem. No stall or shudder when I pinch the yellow hose. I've also read this article people have posted on here before: http://www.myhyundaiforums.com/TSB/xml/06-36-006.swf
It's difficult to test the vacuum when the hoses are so corroded they will break when removed so I'm shopping for replacement hoses now and I will just switch them out and check the metal pipes for blockages. Since my egr valve is new I am looking at buying new vacuum valve and solenoid. But where to buy the hoses and know if the solenoid/vacuum valves are right for my 2003 4cyl?
Danc83 is offline   Reply With Quote Quick reply to this message
