2.7 Spark Plug Change - Hyundai Forums : Hyundai Forum
Old 10-19-2010, 03:21 PM   #1 (permalink)
2003 2.7 Santa Fe 2001 3.0 Z3
I found this on the internet with a picture guide on changing the spark plugs on a 2.7 santa fe. Any thoughts from anyone who has done this as to how good a guide this is? My local dealer wants $500 to change the plugs and I'm thinking about doing it myself. Here is the site:
http://santafemods.com/Mods/SparkPlugReplacement.htm
Old 10-19-2010, 04:17 PM   #2 (permalink)
NGK Platinum or NGK IRIDIUM (upgrade) and new set of Hyundai plug wires since intake already off and mileage... bad to have a misfire code next week and have to do it all over again..
Old 10-19-2010, 06:53 PM   #3 (permalink)
pemdas1972's Avatar
Drives 2002 Santa Fe LX 2.7 4wd 173,000 miles
pemdas1972 is an unknown quantity at this point
Yes, I used this guide to do my plugs and it was accurate for me. It took me about an hour to do the job. Just make sure you put a new plenum gasket and as sbr711 stated to replace the wires and use NGK spark plugs.
pemdas1972 is online now   Reply With Quote Quick reply to this message
Old 10-19-2010, 08:14 PM   #4 (permalink)
QUOTE (pemdas1972 @ Oct 19 2010, 04:53 PM)
Thanks, I was wondering if anyone had done this as a guide. I'll try it this month.
Old 10-19-2010, 08:50 PM   #5 (permalink)
audiracer88
If you're going to replace the spark plug wires, I recommend Magnecor KV85 wires. They're the best you can get and you won't have to replace them for a very long time!
NGK iridium plug are the way to go too. They don't need to be replaced for a long time either. Saving you needless repeats of this job.
audiracer88 is offline   Reply With Quote Quick reply to this message
Old 10-20-2010, 06:25 PM   #6 (permalink)
QUOTE (johnaauld @ Oct 19 2010, 06:14 PM)
Just got done changing the spark plugs. Have to say up front that I used the champions that the dealership sold me last year and they cost around $60 if I remember right. I had changed the three up front last year so just changed the back three today. I would have to say there is one tool missing on the list. I think a magnetic wand to pick up dropped tools(for me it was a 12mm on a stubby extender that I managed to drop. It was also good for fishing out the spark plugs(my spark plug remover doesn't have any rubber insert). The only other thing I had a problem with is when it said to lift plenum off studs. I yanked and pulled and tugged for a good long while without budging it a bit. Finally I carefully pried the sides with a flat blade to get it started to move. I also saw some aluminum shavings around the stud and bolt holes that I carefully brushed to the outside before I put the cloth on the intake side. Took me two hours but I'm not the worlds greatest mechanic and some of the problems stated above where a good part of my time. Thanks again to whoever put that post together. I wouldn't have done it without it and the dealership would be $500 richer.
Old 11-16-2010, 03:09 PM   #7 (permalink)
bdh
bdh
Thumbs up
The link provided for the spark plug replacement seems straight forward enougn...but shouldn't I be concerned with the torque values for reinstalling everything?
Does anyone know the proper torque values for the plenum bolts?
Thanks,
Bruce
bdh is offline   Reply With Quote Quick reply to this message
Old 12-08-2010, 09:13 AM   #8 (permalink)
techjpc
QUOTE (pemdas1972 @ Oct 19 2010, 06:53 PM)
What is a plenum gasket and where does it go ? Also, he mentions a Metal Crush Gasket, what is that ?
He never says what to do with these two items.
Joe
techjpc is offline   Reply With Quote Quick reply to this message
Old 12-08-2010, 11:25 AM   #9 (permalink)
QUOTE (techjpc @ Dec 8 2010, 07:13 AM)
Joe
If you go to step 16 and look at the picture- you will see the black gasket that runs the length of the intake. I'm not sure what the metal crush gasket was for as I did not notice it while doing this repair. I reused the original gasket on the intake when I did my spark plugs and had no trouble after the job was finished- the car started right up with no air leaks in the intake. As to the poster above you, it took a fair amount of torque to get the bolts and nuts off the intake and I used a fair amount putting it back on. Didn't use a torque wrench. Hope that helps.
Old 12-08-2010, 07:28 PM   #10 (permalink)
Plenum gasket -- see picture.
Tighten plenum bolts to 17 lb-ft, same for rear bolts at support bracket.
