P0320 Code - Hyundai Forums : Hyundai Forum
Old 08-06-2010, 04:14 PM   #1 (permalink)
keymanrick
2004 Santa Fe tac is not working properly. I get a P0320 Code.Cold someone tell me how to repair this and where the part or sensor is located for this problem.
keymanrick is offline   Reply With Quote
Old 08-06-2010, 04:17 PM   #2 (permalink)
Mr Pogle's Avatar
Drives an i10 style
Mr Pogle
Send a message via MSN to Mr Pogle
Hi and to the forums.
I'm moving this over to the Santa Fe forums where you'll get more help.
Dave
Mr Pogle is offline   Reply With Quote
Old 08-07-2010, 08:26 AM   #3 (permalink)
QUOTE (keymanrick @ Aug 6 2010, 04:14 PM)
0320 is applicable to both the 2.4 & 3.5......... Which engine you got ??
sbr711 is offline   Reply With Quote
Old 08-07-2010, 01:05 PM   #4 (permalink)
keymanrick
QUOTE (sbr711 @ Aug 7 2010, 08:26 AM)
2.4
Old 08-07-2010, 10:22 PM   #5 (permalink)
QUOTE (keymanrick @ Aug 7 2010, 01:05 PM)
2.4
General Description
Ignition failure sensor is used to check whether the spark ignition is occurred correctly or not and also used to tachometer drive. The sensor monitors the voltage difference between a resistance which is on the battery circuit for ignition coil. When the ignition coil works properly, the electric current through the resistance is detected as voltage drop. This is confirmed for every ignition event with the crankshaft sensor and the camshaft sensor. If PCM detects a malfunction, no ignition is possible, so the engine would not start. If there is no ignition signal for a predetermined cycle for one or two ignition coils, an ignition coil circuit failure exists.
Old 08-09-2010, 04:05 PM   #6 (permalink)
keymanrick
QUOTE (sbr711 @ Aug 7 2010, 10:22 PM)
General Description
I can not find the IG Failure sensor at any auto parts stores. Could this part also be called a Camshaft sensor? It seems to look and be in the same place/ Thanks
Old 08-09-2010, 04:13 PM   #7 (permalink)
QUOTE (keymanrick @ Aug 9 2010, 04:05 PM)
Part number is : 27370-38000 (new part number) -- $80 and change, available at Hyundai and Kia dealer... spot on our shelf is currently empty this afternoon
Old 08-14-2010, 02:31 PM   #8 (permalink)
keymanrick
QUOTE (sbr711 @ Aug 9 2010, 04:13 PM)
That part worked Thank You Very Much
