Fuel Filter Replacement - Hyundai Forums : Hyundai Forum
Old 02-23-2010, 09:43 PM   #1 (permalink)
ashlar
I would like to get detailed instructions on replacing the fuel filter on an 2004 Hyundai Santa Fe 2.7L V6. I have tried hmaservice.com but couldn't find any information specific to my model on this issue.
Thanks.
ashlar is offline   Reply With Quote Quick reply to this message
Old 02-23-2010, 10:46 PM   #2 (permalink)
==sYc==>
REPLACEMENT
1. Lift up the vehicle.
2. Reduce the internal pressure of the fuel lines and hoses and make the following operations.
A. Disconnect the fuel pump harness connector at the fuel tank rear side.
B. Start the engine and after it stops, turn the ignition switch to OFF.
C. Disconnect the battery negative (-) terminal.
D. Connect the fuel pump harness connector.
3. Remove the two fitting nuts while holding the fuel filter nuts securely.
4. Remove the fuel filter mounting bolts, and then remove the fuel filter from the fuel filter clamp.
Tightenging torque
Fuel filter fitting nut:
30 ~ 40 Nm (300 ~ 400 kg·cm, 22.1 ~ 29.5 lb·ft)
==sYc==> is offline   Reply With Quote Quick reply to this message
Old 02-23-2010, 11:16 PM   #3 (permalink)
ashlar
Thanks for the response, but that is not the procedure for my make of vehicle.
This fuel filter is located inside the fuel tank and can be accessed by removing the left rear seat and cutting the carpet to gain access to the gas tank access panel, etc. The filter is part of the fuel pump assembly.
_________________________
2004 Hyundai Santa Fe V6 2.7L Engine
Old 02-24-2010, 08:11 AM   #4 (permalink)
==sYc==>
QUOTE (2004 Santa Fe 2.7L owner @ Feb 23 2010, 11:16 PM)
That is the procedure listed in HMAservice.com for a 2004 Santa Fe. Have you tried looking?
If you need to change that filter then maybe your question should have been more specific. Looks like you have the procedure so good luck with that.
Old 02-24-2010, 08:31 AM   #5 (permalink)
jsinton's Avatar
Yes, it's not the first time I've seen this. Hmaservice seems to drop the ball on the Santa Fe and the XG from this period.
Here's the DIY for Elantra from the period. It will give you an idea of how to do it and what it should look like.
http://www.elantraxd.com/DIY/fuel.php
Old 02-24-2010, 09:16 AM   #6 (permalink)
Drives a 2006 Santa Fe 2.7
Hyundai_81
is it possible or nesscessary(sp) to change a fuel filter on a 2006 2.7 santa fe? I heard its inside the tank??
Hyundai_81 is offline   Reply With Quote Quick reply to this message
Old 02-24-2010, 09:23 AM   #7 (permalink)
jsinton's Avatar
Your owners manual says to change the fuel filter every 52.5K miles for a 2006 Santa Fe.
Old 02-24-2010, 10:00 AM   #8 (permalink)
xblazingwinter
Any instructions or clue on how to replace the purge valve?
xblazingwinter is offline   Reply With Quote Quick reply to this message
Old 02-24-2010, 10:05 AM   #9 (permalink)
jsinton's Avatar
That question deserves a new thread. Make a new thread and indicate which engine.
Old 02-24-2010, 01:57 PM   #10 (permalink)
ashlar
QUOTE (jsinton @ Feb 24 2010, 09:31 AM)
Thanks for the procedure. That's what things look like. I have printed things out to follow along, just in case. I have tried looking at Hmaservice and couldn't believe the procedure is not listed on there, hence the reason I came on here.
Thanks again.
